Need advice/help!
smcclain03
Hello all. I'm new here so bare with me :) Anyhow.. I am wanting to upgrade my 6 year old custom built desktop. Now I'm not sure if you can see my specs for my pc, if not let me know please. My question is this: Would I need to upgrade to a Windows 7 os (I haven't decided on which version) from my current Vista or would I have to just wipe everything and do a fresh install of the new os? I will be upgrading my RAM to at least 4gb... if not 8. Will upgrade my CPU soon enough to. Also.. what I have, would it even work for Windows 7? Any help/advice would be appreciated! Thanks!
    E6600 Core 2 Duo 2.4Ghz
    EVGA Nvidia Nforce 680i SLI
    3gb
    Nvidia Geforce 9400 GT
    Creative SB X-Fi
    Samsung SyncMaster
    Seagate SATA 7200 rpm 250gb
    Microsoft Laser
    Microsoft Wireless
    30mb
Welcome
You have come to the right forum for that information. We do not guess, but will send you directly to the source
Find out if your computer is capable of Seven, from the upgrade advsior
Windows 7 Upgrade Advisor - Download - Microsoft Windows
You should then do a clean install, even if you have the cheaper upgrade Seven.
http://www.sevenforums.com/tutorials/31402-clean-install-upgrade-windows-7-version.html?filter[2]=General Tips
A clean install removes all the problems, virus etc. An upgrade covers them very neatly, but maybe not forever.
If you do an upgrade, your stuff will be saved, but you will most likely have problems down the road. Do the clean install.
This will tell you, however, if you can upgrade even though most here would agree that you should not upgrade but do a clean install.
http://windows.microsoft.com/en-us/w...ows-7?T1=tab02
I think that with your specs, Seven would not be a problem, but the upgrade advisor will pick up areas, as well, not shown in your specs, such as memory or hard drive problems
Take it from someone with experience: if you buy an upgrade license you might have to install Vista first and then perform the upgrade because 7 won't activate automatically otherwise. Microsoft might or might not help you with activation on a clean install of an upgrade license. However if you want to get 8 gb of ram you will have to have the 64-bit version of 7 and you can't upgrade to that from a 32 bit version. If that's the case Microsoft will have no choice but to help you with activation. Personally I don't see the point in having that much ram.
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
