Solved Need advice on an old PC with XP
MrInferno
So here's the deal, I have this old Dell Dimension 2350 which is still using the older Windows XP operating system. I have an antivirus, antimalware, etc but I just don't feel safe anymore using XP. I was thinking about installing Windows Vista on this PC, but I wasn't sure if it would run good enough seeing as it is older hardware. Here are the main specifications of the Dimension: Intel P4 2.4ghz (Northwood), 2GB DDR ram, 250GB IDE HDD, 82845G Graphics Controller. Is Windows Vista the way to go with this system or should I install a different version of windows (7/8/10)?
Download and run Microsoft's Vista Upgrade Advisor. It's here.
    Vista Home Premium x64
    Dell Inspiron 546
    Sempron LE-1300
    2GB DDR SDRAM 800MHZ-2X1GB DIM M
    Integrated ATI Radeon HD3200
    VIA High Definition Audio
    Samsung 32" HDTV
    1366 x 768
    320GB NCQ Serial ATA (7200 RPM) w/ 16MB DataBurst Cache
You should get more ram if you want to upgrade the OS and at this point if I where you I would go with 7 or higher. Major software manufacturers are starting to drop support for Vista. Not only that but Vista has barely less than a year to go for support from Microsoft. :( Unfortunately there aren't any drivers for anything higher than XP so if you upgrade you could experience problems.
    Windows 7 Pro & 10 Pro
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB & 500 GB
You posted a similar question on the Windows 7 forums, and even though I'm a much bigger fan of Vista, I will say one thing for Windows 7 and 8x: they both run much much better in RAM restricted environments (1 or 2 GB of RAM) than Vista does. I would say Vista REQUIRES 2 GB to really shine. Admittedly it's a pig. Besides, I find the x86 version of Vista sluggish.
So I would recommend either the 32-bit version of Windows 7, 8.1 or 10. I don't think you want a different OS do you? (I was judging from the Linux recommendations you got on the Windows 7 Forums). What is it you're hoping to do with your system? you never really mentioned that yet. That will help judge if your system can swing it.
    Windows 8 Pro x64
    HP 8300 Elite Small Form Factor PC
    Intel Core i5-3470 3.3GHz Quad-Core
    Proprietary
    16 GB DDR3 RAM
    Intel Data Port on-board video
    Intel Integrated HD Audio
    Samsung SyncMaster 213T 21" 4x3 Flat Screen
    1600x1200
    250 GB SATA HDD
    Proprietary
    HP 8300 Elite Small Form Factor Case
    CPU Fan/Heat Sink
    Microsoft USB Optical Mouse
    PS/2 Keyboard
    10 mbps
    Browser: r3dFox ESR 128.12 rc
I ran the upgrade advisor for 7 a while back and it said I didn't have enough RAM. I have 2 GB but with an integrated graphics card. Are you saying 7 would run better on my x64 than Vista? If so maybe I should upgrade. Thanks.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
IMO 2 gb is barely enough for either but if you are sharing memory with integrated graphics that leaves even less for your programs. Therefore it is my recommendation that you get more ram; your system will show to a crawl if you don't have enough. To answer your question it is my experience that 7 is a little better on memory management. On my desktop I only had 2 gb but I wouldn't do that now.
    8 gb
    1 TB & 500 GB
I would agree with that yes. Though running the x86 versions might give you a tad better mileage. How much memory are you setting aside for the video memory?
    Windows 8 Pro x64
    Proprietary
    16 GB DDR3 RAM
    1600x1200
    250 GB SATA HDD
    Proprietary
    CPU Fan/Heat Sink
    PS/2 Keyboard
    10 mbps
Are you saying I'd be better off with 7?
From what I remember from the upgrade advisor it's a half or quarter gig. I remember wondering why it was telling me I lacked RAM until I realized my graphics card was integrated.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
I'm saying that either will seem slow unless you get more memory especially if a half gig is going to video.
    8 gb
    1 TB & 500 GB
Okay but it seems like you're saying 7 would be better as far as RAM is concerned.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
Yes it would, but I would use the 32-bit version. Executables use a smaller word-length and therefore less memory than their 64-bit equivalents.
    Windows 8 Pro x64
    Proprietary
    16 GB DDR3 RAM
    1600x1200
    250 GB SATA HDD
    Proprietary
    CPU Fan/Heat Sink
    PS/2 Keyboard
    10 mbps
Yes it would however for potentially only 1.5 gb XP would be best. But if you do upgrade try to keep at any one time to a minimum or your system will seem really slow.
    8 gb
    1 TB & 500 GB
Vista came with my machine and I can't say I've ever felt things were slow. My only real complaint is that I can't play certain games but that's to be expected with my specs. I was given Windows 7 x64 upgrade disks when I bought my PC but I didn't think I really had a reason to upgrade outside of losing Chrome in April but you guys think I'd be better off with 7? Maybe I should upgrade. Thanks for the replies BTW.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
I think you need more ram.
    8 gb
    1 TB & 500 GB
Okay, thanks.
    Dell Inspiron 546
    Sempron LE-1300
    Samsung 32" HDTV
    1366 x 768
Sorry for late reply guys, I ended up going with Linux. It's running well on this older system, thank you for the suggestions though. To answer the question of, "What will you be using the system for?". This system is only going to be used for very basic tasks, some browsing etc. It's more of like a, living room pc. Nothing too complex for the old pc.
is there any offline version of the windows upgrade adviser ? The online version is not supported anymore :
    Windows xp
