Need help and fast!
ericmack
I am currently having a lot of difficulty with my laptop, for some reason when i try to type something it doesn't type it does short keys like (eg. i press h and it opens history) it wont type at all at times, sometimes it works and sometimes it doesn't is there any way i could fix this please help!
i am running:
Windows Vista Home Premium 32bit
if it helps
What programs did you install recently?
    Dell
    Q6600
    HP w2207h
Hi ericmack and welcome to Vista Forums :party:
Are you catching the Ctrl key by any chance? Holding down that key and pressing H opens the history.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
is it possible that my ctrl key is stuck?
Absolutely. Some spilled coke will do that. Jerk it a bit and see whether comes loose.
    Dell
    Q6600
    HP w2207h
    Intel I5-2500K @3.3GHz
    Asrock P67 Extreme4
    EVGA GeForce 750 Ti SC 2GB
    auria eq2367
    SeaSonic X 650W 80 Plus Gold
    Corsair Obsidian 750D
    Logitech Wireless Mouse M310
Has the sticky keys feature in the ease of access center located in control panel been turned on?
    I5 3570K
    Gigabyte Z77-DS3H
    Gigabyte Geforce GTX 660 TI
    creative x-fi
    Both 1680 x 1050
    Technika TKOPTM2
    Logik
