You are using an out of date browser. It  may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Need help desperately, Unknown devices problem
					So one day I turned on my computer from a hibernation, and the windows didn't resume correctly, so i dumped the restore and just rebooted. Following that, none of my usb devices worked. In my device manager, under Universal Serial Bus controllers, there are two unknown devices (I uploaded a picture).
I've looked all over microsoft support for an update that would help, and I couldn't find anything. PLEASE HELP!! I NEED MY FLASH DRIVE FOR COLLEGE!!
					54.7 KB
					Download a program called DriverMax.  There is a free trial for this.  This program has an "Unknown Devices identifier" and is very easy to use
DriverMax looks promising and it is free.  Thanks
					Home Built
					Intel Core 2 Quad Q6600 Kentsfield
					GIGABYTE GA-EP35C-DS3R
					OCZ Reaper HPC 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
					SAPPHIRE 100242L Radeon HD 4850 512MB 256-bit GDDR3 PCI Expr
					On Board
					Acer B223Wbdmr Black 22" 5ms Widescreen LCD Monitor with Height & Pivot Adjustment 300 cd/m2 2500:1
					Western Digital Raptor X WD1500AHFD 150GB 10000 RPM 16MB
Western Digital Caviar SE16 WD7500AAKS 750GB 7200 RPM 16MB
					Antec NeoPower 650 Blue 650W ATX12V / EPS12V SLI Certified C
					Antec Twelve Hundred Black ATX Full Tower Computer Case
					9 different Optical Drives installed for review purposes
					probably a registry error. If drivermax doesn't work, try a repair install.
					E8400
					asus p5ql-e
					ocz pc 1066 2x2gb
					asus eah3650 silent
					Edirol UA-25
					Gateway FPD2185W
					1680 x 1050
					750g samsung
					Zalman ZM460B 460W
					Lian Li A05 + 2 x Sythe S-FLEX SFF21D 120mm case fan
					Coolermaster Hyper Z600 fanless CPU cooler
					Microsoft Laser Mouse 6000
					Merc Stealth
					DSL
					Problem is drivermax doesn't work on X64??
