Need Help,Please
George J
I need to install the following DLL.D3DRM.DLL which must be installed in VISTA so I can operate my FSM Simulator.It has not worked sence I switched over from XP to Vista.Apparently it was removed from Vista and is required to operate the FMS Simulator.I have the following instuctions(which confuse Me) a.Reinstall the FMS Simulator.Then go to http;//www.driverskit.net/dll/494.html and enter the code you see at the bottom of the page.EXTRACT??D3DRM.DLL Move DLL D3DRM.DLL to the Folder C:\Windows\System32.Restart the FMS application and it should work perfectly. For some reason it will not work???>? Help[George Hayes:eek:
what doesn't work, is it the website address?
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Firstly to get to the C:\Windows\system32
first go to start then computer
then click you C:\ Drive usually the first Hardrive
Now double click the Windows folder
Then scroll down till you see a system32 folder
Now your are in C:\Windows\System32
As for extracting, Extracting is were you unzip a file in a Zipped file or a .rar file and move it to a specific place as in your case to move it to C:\Windows\System32
You may need WinRAR to help extract this see WinRAR (32-bit) - Free software downloads and software reviews - CNET Download.com for more details
Josh
    AMD HD Radeon 6870
    Novatech Night
Shadowjk That info will be useful for several people:)
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
    AMD HD Radeon 6870
    Novatech Night
