need help with BSOD problem
xmage
It happens a few times i accidentally deleted the minidump using ccleaner so i unable to upload it.
    E5300
    ECS G31T-M7
    2GB PC-6400 800mhz
    ECS nvidia 8400gs
    160GB SATA drive
    HP Pavilion M9040N Elite Desktop PC
    2.4 GHz Intel Core 2 Quad Processor Q6600
    Intel G33 Express Chipset
    4 GB RAM DDR2-SDRAM PC5300 @ 667Mhz
    Nvidia 8800 GTS 640 MB
    HP 22'' Widescreen
    1680X1050
    Serial ATA Dual 320 GB hard drives (640 GB total) and HP HD3000S Personal Media Drive 300 GB USB 2.0 External Hard Drive
    Standard HP Case
    3 Fans and heat sink
    Microsoft Compact Optical Mouse 500
    Microsoft Comfort Curve Keyboard 2000
    DSL 2GB
    Upgraded the power supply to 600Watt, in order to get the Nvidia 8800 graphics card to run. And added 1GB of memory even through 32 bit Vista will not use it all.
Sorry i accidentally delete the minidump after i use ccleaner, possible to solve with the picture of codes shown?
my specs
intel E5300 2.6Ghz(overclock to 2.9)
2GB PC-6400 800hz DDR2 ram
ECS G31T-M7 motherboard
8400gs graphic card
160GB hard disk
    E5300
    ECS G31T-M7
    2GB PC-6400 800mhz
    ECS nvidia 8400gs
    160GB SATA drive
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
As you can see in his question, he has deleted the dump files.
Can you upload the dump files next time you get a BSOD?
Tom
ok sure but is it possible to solve with picture of the codes shown ?
    E5300
    ECS G31T-M7
    2GB PC-6400 800mhz
    ECS nvidia 8400gs
    160GB SATA drive
    HP 22'' Widescreen
    1680X1050
    Standard HP Case
    DSL 2GB
