Need Help xD
pinakfans
ok i have a gateway laptop p series p63 windows vista x32 sp2.
I have been updating and etc got everything going. but i can't find the drivers or device for mobile intel 965 express chipset family
ive tried the intel site numerous times. ive done the specific product search.
im at my ends with this, and im asking you guys to help me find it.
    Toshiba A135-S2345
    1 GB
    140 GB
Is there anything that you can't do that you should be able to? With XP you need chipset drivers however Vista has a lot more drivers built into the OS. Maybe there aren't any because they aren't needed.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
well its mainly for my gaming. some games wont start and say they can't find a video card etc
    Toshiba A135-S2345
    1 GB
    140 GB
how do i install it? through device manager?
and here's the issue:
    Toshiba A135-S2345
    1 GB
    140 GB
No - Extract the files from the download to a folder, then double-click on the installer inside (Setup.exe)
This launches the installer that will do the job properly.
    Acer Aspire 8930G
i fixed it. i think. when i was in device manager and i went to update, i went to let me pick. and it had a list of intel 82945G express chipset controller 1. and now the games start up
    Toshiba A135-S2345
    1 GB
    140 GB
thanks man!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Toshiba A135-S2345
    1 GB
    140 GB
