Im a gamer and i have the toshiba satelite a135-s7403 and i need to know how to clear allthe files i dont use so i can make t a gaming computer. If there is anything to help someone please tell me.
Update your system specs. when I google model, you shouldnt even be running Vista on that PC even though it comes preinstalled. That pc should not be a Gaming PC, unless you do some major upgrading. It has the Intel GMA 950 graphics processor that isnt meant for any gaming whatsoever. Your PC is meant for basic office/business operations.
IDT High Definition Audio/SRS Premium Sound/Altec Lansing
17" Laptop Screen
1440 x 900 laptop, external 17 in LCD 1024 x 768
WD Scorpio Blue 320 GB SATA 5400 RPM
Toshiba 68 GB SATA 5400 RPM Second Drive (backup)
8 Cell Lithium Ion Battery
Laptop with "light up" HP Logo on outside
Insane air coming out of Targus dual fan cooler
Microsoft Wireless Mobile Mouse 3000 / Touchpad
Full Keyboard with numpad
Comcast Cable 20 MBps
Used Primarily for CAD design using SolidWorks 2010.
Also I love to watch HD movies using the HDMI output(Netflix).
Linked to my Xbox 360 for Windows Media Center
3 USB ports + USB/eSata
HP Remote for Windows Media Center and Quickplay
Internal Dual Layer DVD+/-RW
External HP Lightscribe Dual Layer DVD+/-RW
HP Webcam and Microphone
17" Laptop Screen
