Okay I had my computer running in sleep mode for a few days without use. When I went to use it, I had programs running and it froze. I tried ctrl-alt-dlete. Still nothing, I was in a hurry. So I pressed the power button, then I pressed and held it to shut the thing down. As I was doing this it started shutting itself down so I stopped. It was running extremely slow and I was in a hurry so I just held the power button on the tower to shut it down.
When I went to turn it on I got the usual, windows was not shut down properly. Choose system repair (reccommended) or start normally. After I press one I get this odd loading bar that says something like "loading windows files". Afterwards I get the usual black screen with green loading bar. But then the screen goes to solid blue looks like its going to load but just stays there with the pointer mouse.
How can I fix this?
How can I fix this?
