Need new power supply
bobtran
Power User
Well I finally did it...upgraded one too many pieces and now I need a new power supply. Actually I think mine is due to be replaced anyway (I might be seeing some instabilities). I ran a psu sizer and it recommended at least an 850 watt. Now this may work at this time but I am thinking about potential upgrades tomorrow (ROFLOL, I know me). Anyway I was wondering about recommendations for a good psu based on my system currently (See system specs).
Currently looking at:
  1. Cooler Master Real Power Pro 1250-Watt Power Supply - SLI Ready, 80PLUC, 135mm Fan RS-C50-EMBA-D2 at TigerDirect.com
  2. Corsair CMPSU-1000HX 1000-Watt Power Supply - ATX, 140mm Fan, SATA-Ready, SLI Ready at TigerDirect.com
  3. Ultra X3 ULT40311 1000-Watt Power Supply - ATX, SATA-Ready, PCI-E Ready, Energy Efficient, Modular at TigerDirect.com
I'm not sure about the Ultra brand which is what I am currently running as it only has a 3 year warranty which coincidentally is just how long I've had the current Ultra psu and it is starting to act up.:rolleyes:
    Systemax N2000
    Q6600 (G0 stepping)
    XFX nForce 680i LT
    4 X 2gb OCZ SLI-Ready PC-6400
    Dual XFX GeForce 9800GT 512MB in SLI mode (Stock)
    Integrated High Def audio 192 kHz/32-bit eight channel
    1 24" Septre widescreen, 2 17" Optiquest Q171b's
    1920 x1200 Sceptre / 1280X1024 Optiquest's
    250GB 7200 RPM SATA II
    Cooler Master Real Power Pro 1250W
    n2000
    Thermaltake bigwater 760is - Liquid cooling
    Microsoft wireless laser Mouse 6000
    MicroSoft wireless 6000 v2.0 keyboard
    Wild blue -darn it 1.5mb down and 200k up 17gb p/month FAP
    Windows home server x86(1.5 Tb on 5 drives), Ubuntu 9.0.4 x86, vista x86 sp1, XP pro sp3 x86. SQLserver 2005, MySQL DB 5.0.
bobtran,
I think the Coloer master and Corsair are both solid supplies capale of delivering their rated power and then some. I have been an Antec fan and the 450 watt Antec in my first build is coming up on 6 years old and still going strong. I just used another Antec in my new build. They are reasonably priced and conservatively rated high quality supplies.
R.
    Home Brew
    Intel Core Duo e8400
    Asus P5Q Pro
    G.Skill 2x4gb DDR2 1066
    Sapphire Radeon HD4870
    on board
    LG 22 in.
    Seagate Barracuda SATA 320gb
    Antec Earthwatts 500 watt
    Antec 300 Gaming
    Stock on CPU and three Antec 120mm fans.
    Gaming
    Crappy Wireless
    10mb down and 1 mb up
the ultra x3 is a GREAT psu its the best one i have ever had + its the best warranty in the psu market lifetime replacement even if its your fault
i'd buy a x3 again and again
    AMD Athlon X2 5000+ @ 2.6Ghz
    Acer Micro-ATX Motherboard
    ATI HD3870 with 512mb GDDR4
    Realtek HD 7.1 Onboard Sound
    22" Acer X223 Widescreen
    1680 X 1050
    ULTRA X3 600 Watt Modular
    Microsoft Sidewinder X5
    Microsoft Sidewinder X6
    6 Mbs Down 1 Mbs Up
One thing to be aware of when choosing a new/replacement PSU is Will it fit in the case? The depth (front to back) of PSUs is generally 140mm, but some of the higher powered models can be 180mm or even 230mm for the highest powered units (typically those with a rating of 1000W and up). It is possible that these will fit, but you may need to be careful with the connections to the optical drive(s) and you might also need to have right-angled connectors for them. If you have spare drive bays, you might also consider moving the drives so that the connections are not interfered with.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
hm... for your rig you prolly don't need more than 850 anyway...... :D
    1680 X 1050
    6 Mbs Down 1 Mbs Up
Thanks for all your valuable assistance with this decision.
While it is true that at this time I only need about 850 Watts I also find that the limited number of connections on these PSU's will limit future upgrades. I also appreciated the input about the size of the units as that completely slipped my mind when I was researching PSU's. It's always the little things that bite you when you overlook them. Lucky for me I have a full size case with lots of room.
@ Pizzaman: As to the lifetime warrenty on the Ultra, You must have got it at the right time because it only has a 3 year limited warrenty now. I have had a number of Ultra's that have worked flawlessly over the years and for that reason almost ordered the X3 on sale for $199 but it went up to $249 yesterday.
After taking all advice into account I have decided to order the Cooler Master Real Pro 1250 (It has room to grow, a wealth of connectors, and it's SLI certifed by Nvidia for my hardware).
Now All I have to do is wait for the delivery.:D
    Systemax N2000
    Q6600 (G0 stepping)
    XFX nForce 680i LT
    n2000
This is always the l...o...n...g...e...s...t time. The closer we get to something (e.g. number of days before W7 is publically released as RC), the slower and longer the days seem to be.
Good luck with your new PSU (when it arrives) and remember to double (and triple) check all connections BEFORE you turn your system back on. It might be prudent to clean out any dust that might be lurking in your case and to check that all fans are also clean.
    Gigabyte IF233
no they all have a lifetime warranty you just have to register it..... its very simple to do
    1680 X 1050
    6 Mbs Down 1 Mbs Up
Thanks for the info. It wasn't posted anywhere except on their warranty web site. I guess I should have listened. Next time I will know.
For other people searching/reading this posting here is the link:
Ultra Product Registration
From the link:
" all Ultra Products Power Supplies and Cases now carry a three year warranty that they will be free from defects in materials or workmanship. In addition, that warranty is upgradable to a LIFETIME warranty by simply registering online. "
    Systemax N2000
    Q6600 (G0 stepping)
    XFX nForce 680i LT
    n2000
yep haha :D
    1680 X 1050
    6 Mbs Down 1 Mbs Up
