Solved Need Vista Help
Kasya
Hello,
i have Windows Vista Ultimate. I activated it once. Now i am going to buy a new PC and i want to activate my Vista on this new PC. Is it possible, or i have to buy a new Vista for that?
Thanks,
Kasya
    Intel Pentium 4 @ 2.7Ghz Stock Cooler and Voltage
    Gigabyte GA-8IPE1000G
    768MB
    Geforce FX5200 Overclocked by Kasya
    Onboard (Realtek AC97)
    19" Dell
    Seagate 80GB WD 160GB
    450W
    Asus Something :)
    Stock
    Samsung
    Genius
    100Mbs
    My Ancient PC :)
Hello Kasya,
It depends. If you have a OEM Vista, then it can only be used on the computer that it was first installed on. If you have a retail Vista, then you can install in on any one computer you like at one given time. Since it is being installed on a different computer, you will probably need to do a phone activation if it will not activate normally.
I have Windows Vista Ultimate Student Edition. Can i do the activation?
Kasya
    768MB
    19" Dell
    450W
    Asus Something :)
    Stock
    Samsung
    Genius
    100Mbs
    My Ancient PC :)
As Brink mentioned you will have to activate it by phone if you install it on the different computer. Once activated on the second PC you can't use it on the first one. It doesn't matter which edition of Vista you have.
    Gateway P7805u FX
    Intel PM45
    8GB 1066MHz DDR3
    LG 17" WUXGA TFT
    1920x 1200
    WD 2x500GB
    notebook
    BT/BD
Thanks,
I understand
    768MB
    19" Dell
    450W
    Asus Something :)
    Stock
    Samsung
    Genius
    100Mbs
    My Ancient PC :)
