Needing help for downloads
Hamish
I have recently tried to download certain things for my computer, except i have had pop ups that says my security settings are not allowing me to download this.​
Somethings i can download for example things that are already on my computer (MSN) but need updated it is things that are downloaded off websites for example skype.​
i have been on internet options > security settings and changed my settings so that files can be downloaded, and i have also made the sites trusted sites, if there is anything i am missing can u please help me with it, thankyou​
    Compaq Presario C700 Notebook PC
    1014MB RAM
If that's the case, I rememver that IE has like a bar that will appear below the address and other toolbars that says "Internet Explorer has blocked a download....." or something like that. All you have to do is click on that bar and click on download file. Hope this helps.
    Intel Core2 Duo E2200 2.2 GHz
    Emaxx IG31-AVL (AMI 1.1 Bios)
    4.00 GB DDR2-800 MHz Dual Channel Memory
    Inno 3d GeForce 9500 GT 1GB DDR3
    Realtek 6 Channel On Board
    15" Generic Flat Screen Panel
    1024 * 768
    1 Seagate 80GB 7200 RPM SATA 1 Western Digital My Book Essentials 1TB
    500W
    LGA 775 Compliant Case
    Case Fan (Generic)
    Generic PS/2 Mouse
    Generic PS/2 Keyboard
    1Mbps DL 600Kbps UL
    Altec Lansing 2.1 Sound System Nokia 5800 Xpress Music RM -356 v31.0.101
yes i have done that pop up bar or something that has come up but the same thing happens but thanks anyway. :D
    1014MB RAM
Hello Hamish,
Do you have any third party software, anti-virus/malware, firewall, or anything like that running ?.
Also, have you tried a reset of IE ?, Tools > Advanced > Reset.
Give it a try and post your results, good luck.
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
thanks toney-nutz resetting my internet did it thanks, i am only young so i dont know much about computers so that was good thankyou very much
    1014MB RAM
Your welcome Hamish, glad you got it fixed. :party:
    Self Build
    Asus P5Q Premium
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
ill add u on xbox live, i only got a hardrive recently and one game so im pretty bad gamerscore wise, but im a freak at the game, fifa 09 maybe vs u sometime, ty once again
    1014MB RAM
