Solved Netbook battery not lasting as long as it should!
Smurfyy
Danny :)
Heyy!
So i have noticed that my laptop battery isn't lasting as long as it should...
My netbook is an Acer Aspire One 751h-52yk, ive looked back on the box and it clearly says "4 hours + battery life" and i get 2 hours, 2 hours 30 if im lucky...
The power settings are on power saver, screen brightness on lowest, WiFi on, and no other devices connected.
It is still under warranty, but apparently it doesn't cover the battery..
What should i do?!
Thanks in advanced,
Daniel =)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Can you answer the following questions:
1. Do you run the battery down low and then charge it fully again often?
2. Are you doing highly demanding tasks? Or is it just idling?
3. Do you regularly run the notebook off the battery? Or is it mostly mains?
Tom
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Also what type of battery is it here is the following info for each battery type:
If you frequently drain and then recharge a lithium-ion battery, it can quickly lose its ability to hold a charge. The practice of completely draining and then fully charging a battery is advice that applied to nickel cadmium (NiCd) batteries and, to a lesser extent, nickel metal hydride (NiMH) batteries. Lithium-ion batteries last longer if you charge them often, a little at a time, to maintain a minimum charge of about 40 percent capacity.
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Tom
Hey,
1. Most of the time, i use it at school.
2. Just google chrome open with 5 tabs and windows live messenger normally.
3. mostly battery, but i use mains when i know ill be using it longer that the battery will last.
And its a lithium-ion battery.
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Tom
Hey,
Every time you run a battery low and then charge it back up, it decreases the capacity of the battery and this is probably what has happened to you. The only way to solve this, is to buy a new battery but beware it should cost you around £50
ACER UM09B7D,UM09B7C battery- New Battery For UM09B7D,UM09B7C
Acer Aspire One 751h-52yk battery - Google Product Search
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Okay, thanks for searching for me..
I remember i managed to get 3 hours 30 out of it, but that was ages ago..
A new battery it is, ill check with my dad once more to see if the battery is covered on the warranty.
Thanks again,
Daniel
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Thanks again,
Daniel
No worries :) I'm glad I could help you.
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Just a quick one, how far should i use the battery down to, im on 19% at the moment, any lower or too far?
Daniel =)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Daniel =)
Well you should always try to keep it as high as possible, because low percentages will reduce the capacity of the battery over time, but personally, I try to keep my battery over 50%. But if you have to then thats fine, just don't go below the point when windows warns you of low battery.
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
Daniel =)
With lithium batteries they work best when the charge is above 40% so try and keep it above 40%
    AMD HD Radeon 6870
    Novatech Night
Heyyy,
Good news!
After a bit of an argument with Acer we phoned Tesco and explained to them what has happened.
So in the post in the next few days i should be receiving a brand new 3 cell battery. :party::party:
Daniel =)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Heyyy,
Good news!
Daniel =)
I love arguing on the phone with manufacturers! :devil:
lol.
At least you got some new hardware out of it.
    HP Pavilion Elite
    Some Amount of Motherness
    6.O GB RAM
    Some Amount of Soundness
    1440x900 & 1440x900
    WD Caviar Blue 500GB
    Some Amount of Voltageness
    Hp Pavilion Elite Case
    Some Amount of Coolingness
    HP: M/N:M-SBQ133
    HP: Model Number: KB0911
    Comcast: 20 MB/S
Yeahh
And the best thing is that i dont have to send the old battery back, so now im gunna have roughly 6-7 hours spread out over 2 batteries!!
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Yeahh
Nice. :D
    HP Pavilion Elite
    6.O GB RAM
    1440x900 & 1440x900
    HP: M/N:M-SBQ133
    Comcast: 20 MB/S
Heyyy,
Good news!
Daniel =)
BUMP;
Still havnt received the battery!:mad:
Getting my Dad to ring tesco now :huh:
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
Ignore that post, it just came thru the door, coincidence! lol ;)
EDIT;
After first charge, all the way to the top, it says im going to get 3hours 18minutes!
Better!
Any advice for how far to grin the battery before i charge it?
My dad says all the way, then charge it, but i want a few other opinions please? :)
Its a Lo-ion battery/
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
    HP Pavilion Elite
    6.O GB RAM
    1440x900 & 1440x900
    HP: M/N:M-SBQ133
    Comcast: 20 MB/S
EDIT;
Better!
Most laptops use lithium-ion (Li-ion) batteries. Like most batteries, lithium-ion batteries gradually lose their capacity to store energy as they age, whether or not you charge them. Over time, this change in storage capacity significantly affects the accuracy of the battery meter. If you frequently drain a lithium-ion battery, and then recharge it, it can quickly lose its ability to hold a charge, which affects the accuracy of the battery meter. The practice of completely draining the battery, and then fully charging it, is advice that applied to nickel cadmium (NiCd) batteries and, to a lesser extent, nickel metal hydride (NiMH) batteries. Lithium-ion batteries last longer if you charge them often, a little at a time, to maintain a minimum charge of about 40 percent capacity.
Hope This Helps,
Josh
    AMD HD Radeon 6870
    Novatech Night
EDIT;
Better!
Hope This Helps,
Josh
Thanks, ill Remember that when im out and about, having 2 batteries should be easier to manage; Swap for a fully recharged battery, and charge the other one when im near a power outlet. ;)
    Custom built.
    ASUS M5A78L-M/USB3
    8GB DDR3 @ 1333MHz
    750 watt.
    Foxconn TSAA699.
    4 fans.
EDIT;
Better!
Hope This Helps,
Josh
Just so you know Josh, if you copy text from other websites, you have to include where the information was found just to let the people who wrote that article know, that you aren't nicking their information. So in your case, perhaps it would be wise to add something like this to the end of your paragraph:
Source: Conserving battery power
Tom
    Build #1
    ASUS P8Z77-V PRO
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
