network card issue
jw1089
i recently bought a pci network card, specifically a a Intel PWLA8391GT 10/ 100/ 1000Mbps PCI PRO/1000 GT Desktop Adapter. after the hardware install, i booted up, and to my dismay, vista doesnt recognize that ive installed a new network card. im using the card to hook up my xbox 360, so that i can access xbox live through the university's network. i have the xbox hooked up to the pci network card via crossover cable, and when i turn the xbox on, i get green leds on the back. you think you can help me get windws to co-operate?
Does it show up in the device manager.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Did you install using the drivers that came with the card or have you going to the manufactures support side and got the drivers fr0m there?
    RemnanteK
    Q9300 3.0Ghz @ 1.175v Stable
    EVGA 780i
    4x1GB Corsair Dominator DDR2-8500 (5-5-5-15 :1067)
    EVGA 8800GT 1Gb Akimbo
    Onboard 7.1
    DELL 2005FPW
    1650x1080
    2x 750Gb Seagate SATA 1x 1Tb Seagate SATA 1x 250Gb Seagate SATA
    ABS Tagan BZ 700W
    Cooler Master Cosmos 1000
    Zalman 9700 // CORSAIR CMXAF1 Fans
    MS Explorer 3.0
    MS Ergo 4000
    12MB
Have you tried different pci slots?
sorry for the questions, but i'm trying to eliminate all the things I've had to do in cases such as yours.
    RemnanteK
    EVGA 780i
    Onboard 7.1
    DELL 2005FPW
    1650x1080
    ABS Tagan BZ 700W
    MS Explorer 3.0
    MS Ergo 4000
    12MB
I would try removing the card
Installing the correct (Vista) drivers
Shutdown
Reinstall the hardware making sure the card is seated properly /s securely
Reboot and check device manager for the card / connectivity;)
    Lenovoa 9120-CTO
    AMD Sempron 3600 2.o Ghz
    2GB
    Network Adapter - Marvell Yukon 88E8071 10.64.10.3
Shutdown
so you're saying to remove the card entirely, and then install drivers, then place the card back in? when i already have the card in there, and i try to install drivers, the installation tells me, at the end, that no intel hardware was found. and yes, i did try switching pci slots, though when i did, i got a beep sound from the mobo, so i think im gonna switch back.
