Network Controller problem
Tanaia
I'm having a huge issue with my network controller, ive been looking up and trying every possible thing to fix this. Basically in the device manager it shows up with a ? next to it, i try and update the driver it says it cant find the drivers, i try locating the drivers myself, they wont install. Short of getting a new laptop i have no clue what else i can do.
It used to work before, i ended up getting a virus, and reinstalling windows, ever since i reinstalled windows i cannot seem to get this network controller to work. I have a Inspiron 1526, im using Vista ultimate. I assume that this is the reason i cant find any wireless networks, cant connect wirelessly Any help or ideas you could give would be much appreciated.
Also, im not sure if this is connected, but i cant install Adobe.
OK first of all can you install anything? Have you installed anything else? Could definitely be a Windows Installer issue (as far as not being able to install the driver), I had one a while back. Next, if you could post a screenshot of your Device Manager window with showing the problematic driver ( http://www.vistax64.com/tutorials/289032-screenshots-files-upload-post-vista-forums.html ) I'll try to find a solution online for you, drivers are usually straightforward fixes. Use the Snipping Tool (Go to Start and type "snip" without the quotes) to capture a screenshot. Also, where did you download the driver from? Just in case, save a System Information file by going to Start and typing "msinfo32" without the quotes, then File > Save and upload that file as well as the screenshot, it'll make it easier to figure out exactly what you need. Shouldn't be too hard to fix this!
    Dell Inspiron 1545
    Intel Core 2 Duo T6400 @ 2.00 GHz
    DELL - 27d90219 Phoenix ROM BIOS PLUS Version 1.10 A05
    Generic PnP Monitor (DPMS), 15.3" (34cm x 19cm)
    1366x768
    Internal 320 GB Portable 320 GB used for separate storage of media, plugged into USB port as needed.
    Single built in fan
    Touchpad, + Logitech wireless mouse (USB)
    Built in
    ~150 kilobytes/sec DL
    Usually have low HD free space left (<10 GB), often left on overnight. I really push its capabilities.
