Solved New Problem with Previous Solution
stantonmd
Hello,
Awhile back I was given instructions on how to change the folder standard green folders to new pink folders. Well, my computer crashed out and I had to get a new hard drive.
I tried to follow the instructions from the previously solved thread, but I can not find the "desktop.ini".
When I go to the users folder inside my choices are Administrator and Public and I can not find the "desktop.ini" file.
I have windows vista.
Thank You
Open up Windows Explorer and go to organize, folder and search options, then on the view tab clear the check mark for hiding system files.
    Sony Vaio Z46GDU
    6GB DDR3 1066MHz SDRAM
    13.1" WXGA True Colour Tough
    1600x900
    320GB SATA 7200RPM
    1MB/s
    Sony Vaio Z46GDU
    1600x900
    320GB SATA 7200RPM
    1MB/s
You guys are totally getting tired of me I'm sure, but I really do appreciate any help I can get.
Okay I have chosen the show hidden files and folder and unchecked the Protected files.
Now a "desktop.ini appears but it doesn't have the line for "Icon Resource". It only has this:
[.ShellClassInfo]
LocalizedResourceName=@%SystemRoot%\system32\shell32.dll,-21816
I can't figure out why this was so easy last time and now it seems nearly impossible?
Alrighty my friends I have sucessfully changed my folder icons and I am so greatfull for all the help.
This is an awsome place and I hope you guys get paid for this, even though you are truely PRICELESS! :p
You're most welcome Stanton. I happy to hear that you got them changed. :)
