Solved Newbie followed Vista tutorial but still causes problems help plz?
Ventus
I followed the column width tutorial thing here
http://www.vistax64.com/tutorials/108665-column-customize.html
and a bunch more to make it so all my folder have the default sort by order of name, date modified, type, size so its like xp.
but when I lookit my columns it ends up like this
attachment.php
all the columns are stuck at 80 pixels so date modified is cut off. I did do the obvious method of going to the show more and changing it to 104 which is the size for all of the date modified to show up but that didn't work so thats why i'm asking.
For some reason if I shuffle through the views (I press the view button on the top a few times to go from list to details, etc back to list) and come back to list format, it ends up the way I want it. Like so:
attachment.php
but if i close the folder and reopen it, it ends up the first way. I did press apply to folders after the change was made to see if it sticks but it didn't
My questions is how you set it so I can make it look like the way it does the second time around the first time cause looking at "Date modif..." is sorta annoying.
do i have to reset all the folders and then reapply settings? Anyhelp is greatly appreciated!
Question 2
Also another quick question, is there a way to change all your folders to a single template instead of going one by one? since view settings are set are done by template. and not the subfolder options cause that only changes the options of the subfolders of the root directory or whatever directory you chose.
or if that isn't possible, is it possible the settings for the template for "all items" and apply it to other templates?
    HP DV7 1285 DX
    Intel Dual Core 2.4GHZ
    6GB
    Nvidia Geforce 9600 GT
    500 GB SATA
    Razer Deathadder
Hello Ventus, and welcome to Vista Forums.
You can use the download in METHOD TWO of the tutorial below to reset all folders views with the same folder template and "details" view.
http://www.vistax64.com/tutorials/70819-windows-explorer-folder-view-settings.html
The column width is a bit buggy on how it is remembered. Usually it is remembered on a per folder window basis. Using the download above may help with it being remembered though.
thanks for the help!
    HP DV7 1285 DX
    6GB
    500 GB SATA
    Razer Deathadder
You're welcome Ventus. :)
