garagetinkerer
Hi All!
Any and every help/advice is appreciated... I have an Asus K8-8VM mobo, and (yes it's) an Athlon 3000+ (K8 proc, i know i am to upgrade in a week or 2). The problem is that every time i restart after having installed audio drivers, the OS shows that no audio device is installed. I did some comprehensive googling about the same... however, i only found that i need to switch off my dsl router, if i must have audio on Vista. XP, it does fine for playback and all, it's only Vista which is causing me grief. My speaker system is a 4.1 setup, could that be an issue?
This happens on both Vista X64 or X86 (ultimate versions)
Thanks!
Thanks!
you should report this to Microsoft. Self repairing systems that fix their own problems arent how they are designed to work. these systems need to get worse over time and eventually blue-screen every 15 minutes as per MS design specs.
