No sound after an update.
Parziale
So I just updated Vista on my machine, and after it finished updating, and restarting, my sound was gone.
And every time I try to turn up the volume it says "No Audio Output Device Is Installed".
But it was working before the update. D=
HELP.
PC: HP Pavilion dv 6000 (GM006UA#ABL)
Other bits of information I also don't understand can be found here. I have no idea what that means, but it might be handy information.
can i start by asking, did you use windows update
also, did you install vista SP1 (Service pack 1) just before this problem occured
if you used windows update, open it and click "view installed updates" (top left of the windows update window)
reply to this message and list with all the updates you installed on the same day your problem started to occurr and me/another member will do some digging to see what might have caused the problem...
untill we know this information we won't be able to help you further.
i will keep an eye out for your reply........
    Acer Aspire M5630
    Intel Core 2 Quad Q6600
    Acer
    4GB DDR2
    nVidia GeForce 8400GS
This problem was all ready solved.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Uninstall the drivers & then download & install the latest from the manufacturers website.
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
perform a system restore and the sound will be back.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
Parziale already has the problem fixed by downloading the drivers and installing them from the other thread post.
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
hey,
i have the same problem as well i also updated it n after the sound was gone noting "no audio output device is installed" but mine is
HP Pavilion dv2000 (GA726EA#ABV)
what shall i do!! :S
    Asus M2N68-LA
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Comcrap 10mb cable
This happened to me after upgrading from Home Basic to Home Premium.
I could get no sound for some time then some clever guy in the shop where I purchased my computrer upgraded my sound drivers from "SigmaTel Audio CODEC" to "SigmaTel High Definition Audio CODEC", obtaining some drivers from the internet somewhere, and it has since all worked fine since.
Rgds
Nick the New
