No sound but everything seems to be working
jesse6384
Back in June I installed Vista onto my machine (prior to this I ran xp for 3 years and the sound worked). I was ok with the sound not working since I had a bluetooth headset which worked fine...It's starting to get annoying now.
I have a gigabyte motherboard with AC'97 (ALC850 codec) on board sound card. The driver is up to date. I have the volume icon, and it shows my speakers in the play back device section. When I play an audio file, the green bar lights up on the speaker icon.
I can't find the thread now but I did try the suggestion of opening up the playback devices, right clicking in an empty area and showing all disabled devices...there wasn't any devices hidden.
Hopefully I provided enough information, if not please ask. I really don't want to buy a sound card but it's looking like I might not have a choice.
Thanks,
Jesse
Check to see if you can find updated chipset drivers.
    Jonathan King
    AMD Athlon Dual Core Processor 4850e overclocked @ 2.92 GHz
    ASRock A780 FullDisplayPort
    6.0GB Dual-Channel DDR2 290MHz Crucial Technology
    ATI 3200 (onboard), nVidia 7200 GS (PCIe)
    17" Cybervison ds69T, 17" Starlogic
    1024x768
    WD 320GB SATA, Hitachi 1TB SATA
    Antec ea-430d 430W
    Antec 300
    stock cpu, 120mm rear, 140mm top
    Microsoft Wired Desktop 500 (USB)
    Microsoft Wired Desktop 500 (PS/2)
    9.32 Mb/s download; 0.36 Mb/s upload
    Other OS's: Windows 7 Professional x64, Windows Professional x86, Ubuntu x64
Its start > control panel > sound
That will show you the advanced sound options. It wil also test the sound, if you hear sound during the tests then its a software / configuration issue.
    HP
    Intel Neo
    2GB
    Intergrated Intel Graphics
    Integrated
    160GB
    Power Adapter
    Touchpad
    Acer
    Down: 16mb/s Up: 1.6mb/s
    I killed my HP Laptop :'(
Yes, the chipset driver was updated. Back in June I had to get the chipset driver update for my graphics card to work on vista. I suspect that the problem is probably along these lines.
stat > control panel > sound, then right clicking the speaker icon and selecting test shows the green bar bouncing up and down as if the speaker is working.
well I'd try checking the speakers/headphones on another pc just to make sure if its not them.
also how do you plug it into your case (in the front or the top or at the back?) - if its on the front or top of your case, the line in might just have been knocked out of position inside, so it might be better to plug it into the back.
Also you might want to select your playback device. play some music (there wont be any sound) make sure your headset or whatever you use is plugged into the back of your case - right click the volume icon in the system tray, and select playback devices - choose the one that has the green bar oscillating and set as default - might be your problem.
    Self built
    Q9550 overclocked to 3.93Ghz
    XFX 790i Ultra SLI
    (8Gb) - 2x2GB DDR3 Corsair Dominator Ram 1600Mhz + 2x2GB DDR3 OCZ 1600Mhz
    Asus GTX 280 + Gigabyte GTX 280 (SLI)
    Creative Soundblaster Fatality1 TY ultra Titanium
    3x24" BenQ, 22"Viewsonic
    1920x1200, 1920x1080, 1920x1080, 1680x1050
    2x 750Gb Samsung Spinpoint Raid 1 array 3x 1TB Western Digital
    Antec 1000W
    Gigabyte low end full-tower
    CoolerMaster V10 for CPU 7 120mm fans
    Logitech G9, G7
    Logitech Dinovo edge, dinovo mini
    24mb/s D/L 15mb/s upload - Telstra
    7 Fans - 3 fans integrated 4x case cut to fit and integrated into the case.
