I use this version of the driver (178.24) and have had no problems with the control panel. Try rolling back the driver until you are back to the one from the initial Vista installation and then see if that makes any difference when you reinstall it.
ViewSonic VA1912w Widescreen
Iomega 1.5TB Ext USB 2.0
WD 2.0TB Ext USB 3.0
HI could you please help me to correct this issue. when I try to access nvidia control panel I get the stopped working error, I keep uninstalling the program and reinstalling but it isn't working? how can I uninstall everything of nvidia and start again, including the display drivers? if I uninstall the display drivers I get a blank screen. THANKS IN ADVANCE FOR YOUR HELP
