OEM System change of motherboard
copperfield
Hi
My desktop system came with an OEM version of Vista Home Premium installed. This has since been upgraded to Ultimate.
Unfortunately the mother board has developed a fault and I will have to replace it.
The original motherboard is no longer available (manufacturer gone bust I think) so I have to replace it with a different make.
According to searches on Microsoft, to continue using an OEM version of vista any change of mother board must be of the same make and type as installed on the original system the OS version was licensed to. :(
If this is true I will have to purchase a full version of Vista or try and get another OEM version with a motherboard. (VERY expensive :eek: so not an option)
Has anyone had the same problem and know if this is true or know of a way round this.
Regards
Copperfield
Hello Copperfield,
Sometimes if you use the same brand of motherboards you will still be able to use the same OEM Vista on it, but you will have to check with the OEM manufacturer to be sure though.
You could get a cheaper upgrade version and use this method below to install if you end up having to buy a retail copy.
http://www.vistax64.com/tutorials/68767-clean-install-upgrade-vista.html
You're welcome Copperfield.
i actually wanted to ask a similiar question about this , cuz i ordered a new mobo, new brand and all.. my oem copy didnt come with a system , i just ordered it on NEWEGG.com by itself.. can i actually re-use it? possibly call M$oft..explain the situation..that my old mobo died or something.. and possibly get a new activation key from them? i did that once.. a while back and they activated it for me...just wondering if i might be able to do it again :)
    Intel Core i7 920 2.66ghz @ 3.37ghz 1.33v
    ASUS Rampage II Extreme x58 Bios 1306
    6GB Corsair Dominator DDR3 @ 1604mhz 8-8-8-24 1.65v 1T
    EVGA Nvidia GTX 295 186.16
    Logitech Z-Cinema 2.1 USB speakers @ 24bit 48000hz
    SAMSUNG 2253BW 22" 2ms DVI LCD / Samsung 50" Plasma TV 720p HP-T5064
    1680x1050- LCD, 1366x768 -PLASMA
    300GB 10,000rpm WD Velociraptor 320GB 7,200 WD 1TB 7,200rpm WD 1TB 7,200rpm Seagate 7200.11 2TB External MY book II WD 7,2000rpm /Pioneer 8x BLURAY Burner BDR-203BKS - Sata/ /Samsung 22x DVD Burner w/lightscribe -Sata
    Antec Signature 850 Watt
    CoolerMaster Storm Sniper
    CoolerMaster v8 35c/60c 5 CASE FANS 2x200mm 3x120mm
    Logitech G9 Laser
    Saitek Eclipse III
    20 MBPS Road Runner Pro
    Edirol PCR-500 49 Key MIdi Controller Keyboard 3D MARK 06 Score: 21458 3D MARK 05 Score: 27549 VANTAGE SCORE: P24129 VISTA SCORE: 5.9
Hi EmulatorX,
On a retail OEM copy of Vista that did not come with the computer, it can only be reinstalled on the same computer that it was originally first installed on.
I suppose that you could try to phone activate with MS or the OEM to see if they may activate it for you though under that type of circumstance.
thanks..ill hope for the best when i reinstall the oem on the new mobo , im confident they'll oblige me..
    Logitech G9 Laser
    Saitek Eclipse III
You're welcome EmulatorX. I hope they will be to. :)
