Operating system not found
Shanker
My Gateway laptop using Vista will randomly restart, then stall on the black screen that says "Operating System Not Found." Usually, with a hard reboot, it will eventually find the desktop, but this can take a very long time, up to 30 minutes.
Originally, everything was fine until the computer suddenly became very slow and balky while surfing the Web one day. After it became essentially non-functional, I reinstalled a clean version of Vista with the recovery CD, and everything seemed fine for a day or two before the slowness and random restarts started happening again.
Besides the Adobe 8 flash player, all I have dowloaded since the reinstall are Avira Free antivirus and RegDefense registry cleaner, neither of which seem able to scan completely or update themselves before the computer crashes.
If I can get to the desktop and start Internet Explorer, I can usually navigate quickly and easily as if nothing at all is wrong, but it may take a couple hours to get to that point.
What the heck is going on here? Should I replace the hard drive?
Hello Shanker,
In case it may be the hard drive, then I would recommend that you create a set of recovery discs if you have not already or this is the same type of recovery CD you mentioned using. This way you can restore your Vista using them if needed. You should also backup anything that you do not want to lose to be safe as well.
You might see if running a startup repair may help. I would avoid running a registry cleaner. They tend to do more harm than good, and could be part of your problem.
You may need to do a factory restore again. :(
Gateway Support - Full Factory Recovery
Hope this helps some,
Thanks for your reply, Brink. I hadn't tried F8 before. Unfortunately, I can't do a full factory recovery because the only option missing from my Advanced Boot Options screen is "Repair your computer." Wassup with that?
Then when I again tried to reinstall Vista from the recovery disc, I couldn't install in Partition 1 because there isn't enough room (roughly 4.7GB of 9.5GB available but 6.7GB needed), and I shouldn't put it in Partition 2 because the computer thinks all zillion gigs of it "may fail soon." Where's the smilie that shows question marks flying out of my big round yellow head?
It may take me all night to get there, but do you think this page from Gateway support will be useful to me?
Gateway Support - Factory System Recovery in the Gateway Recovery Center
Incidentally, while typing this message on another computer, the laptop loaded a nearly normal desktop except that the icons at the bottom of the screen seemed to be older-style, including a small rectangular "Start" button instead of the usual big round one without the word "Start." This happens sometimes, along with louder-than-normal clicks and whirrs accompanied by even louder "pop-pops." Blue Screen of Death immediately followed.
What a sick little laptop I have.
That would be how to do a factore recovery from within Vista. If it works go for it. It sounds like you may be needing to get a new hard drive soon though. :(
