Overclocking CPU help
fields999
Hey
I was thinking over overclocking my cpu a bit, and im not sure which program to use, its an amd phenom 8650 x3 2.3mhz.
I was going to use amd overdrive but it doesnt work with my processor.
Does anyone know a good program i can use for this?
thanks
    HP / Custom Build
    AMD Phemon 8650 2.3ghz X3
    Nvidia nForce 720a
    8GB DDR2
    ATI Radeon HD 4650 1GB
    22" HP w2216v
    Hitachi 500gb - Seagate 500gb - Western Digital 1TB
    Cooler Master 600w
    HP
    3x 120mm 1x 90mm 1x 80mm Fans
    Microsoft Explorer Mouse
    HP Multimedia Keyboard
    24mbit
Hey
thanks
try the BIOS?
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    6gb MUSHKIN DDR3 1866
    TWO x EVGA NVidia GTX 285
    Soundblaster Extreme
    ASUS 24inch 2ms LCD
    1920x1080
    4 x OCZ Vertex 60GB, 1 x Western Digital Velociraptor 300GB, 1TB Western Digital Caviar Black
    Corsair 1000W
    Coolermaster HAF 932
    Water cooled
    Microsoft Regular USB w/wheel
    Saitek Cyborg Deluxe
    Cable 15mbps
Hey
thanks
and, not trying to be mean here....but do you know what you are doing?:eek:
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
nope xD
But i was told since my all 3 of my cores are generally at like 16degrees up to about 23degrees. It would be ok to overclock them up a few mhz.
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
nope xD
go into the bios and check things out... only go in small increments...dont do anything drastic or you may say bye bye to your motherboard/CPU.....
    Myself
    Intel Core i7 920
    ASUS P6T Deluxe
    ASUS 24inch 2ms LCD
    1920x1080
    Corsair 1000W
    Water cooled
    Cable 15mbps
basically, you'd want to go into the bios and look for the section "cpu frequency." it is more than likely going to be at 200mhz. you up the frequency by 5 to 10mhz increments. but, as you have an amd processor, by increasing the cpu frequency, you'll be bumping up the hyper-transport link frequency and ram frequency as well, which makes things get screwy if you get it out of spec too much. what you basically do is, as i stated before, up the frequency by 5 to 10mhz increments, reboot and see if you can get into windows. if you can, cool. restart and go back into bios and up the frequency again. reboot and see if you can get into windows. what you are doing is seeing the a good frequency that you can get into windows. if you can't start windows, though, reboot and go back into the bios and set the cpu frequency down to the last frequency you were able to get into windows with. once you got the frequency set, you want to test the overclock with a program like prime95. run the program until either your computer crashes or your computer runs the program for a while (up to you, but i'd say at least an hour) with no problems. if your computer crashes, again, you'll have to go into the bios and mess with the ram frequency and/or the hyper-transport link frequency. for ram, look for a section in the bios named "dram frequency" or something like that. you'll probably have to change it from "auto" to "ddr2 667." go back into windows and run prime95. if you have no problems, cool. if you crash, go back into bios and look for a section labeled "ht link frequency," or something similar. as with the ram, you probably have to change the setting from "auto," and this time set it to "800mhz"
i am actually (honestly, scouts honor) doing this to my desktop right now (and i'm on my laptop right not and was scouring this forum looking for some help too). i have an asus m2a-vm motherboard, athlon 64x2 5400+ black edition, and ati 690g chipset. since i have a black edition processor, i can overclock by changing the multiplier and cpu frequency, if need be. the stock speed of the proc is 2.8ghz and i'm trying to get it above 3.25ghz, but cannot right now, and i'm not really trying to push it that hard. right at this moment, i'm running the prime95 program that has been running since 7:56pm (PST) and i haven't had any problems. what my current specs are: 3.2ghz from 2.8; ht link freq set at 800mhz; dram freq set to ddr2 667; cpu voltage set to 1.45v from default setting; i have a stable temp of 45c during the prime95 test.
if you want to do it, be prepared to spend some time and don't make huge steps in changing settings--just be patient and take little steps.
my two cents
update and fyi: i finished the prime95 run last night (let it run for 2 hours). everything was fine. the extent of my use of my computer is this: internet (obviously), games, and editing and burning family vids. i never really stress the machine greatly, so i'm comfortable with the overclock. i might try for 3.3, though.
    Garage PC
    Intel Pentium E3300 @ 2.5GHz
    BioStar G41-M7
    A-Data PC2-6400 (2 X 2GB)
    Diamond Radeon HD 4650
    Realtek
    HP Mx705 (CRT)
    1152x864
    LOGISYS PS480E12 480W
    Generic Barebones Case
    Stock Intel HSF
    Generic PS/2
    10 d / 1 u
I was wondering, will it damage any other components in my machine though?
Lets say if i went from 2.3ghz to 2.6ghz
    HP / Custom Build
    Nvidia nForce 720a
    8GB DDR2
    22" HP w2216v
    Cooler Master 600w
    HP
    24mbit
Yes you could do damage. RAM is the biggest one to look out for. As has been stated just take it in 5-10MHz jumps and thoroughly test for stability each time.
Try Prime95 (for CPU stability) and Memtest (for RAM stability). Just Google them and you should be able to download them.
    E6750 @ 3.6GHz
    Gigabyte P35 DS3
    4GB 8500C5D
    POV GTX285
    19" Widescreen LG
    1400x900
    2 x WD 500G
    Coolermaster Silent Pro 700M
    Antec 900
    Tuniq Tower 120 LFB
    Logitech MX400
    Logitech EX110
    Graphics Driver - 190.38
One thing no one seemed to notice and no one mentioned,
System Manufacturer/Model Number HP / Custom Build
from his system specs. Which parts are HP and which are custom? If the motherboard is still the original HP motherboard then sorry to say but you can pretty much forget about overclocking, as there will be no options in the bios to do so as HP and (the others) modify the standard bios so that those options are not available.
Also,
You wearing a heavy sweater while sitting at the computer? If those temps are accurate then it must be fairly cool in the room, as it is physically impossible for the cpu to run at less than the ambient/room temperature on air cooling, unless you are using water cooling or some such.
    Me
    Athlon x2 7750 BE
    Asus M4A78 Pro
    2x2gb Kingston
    Sapphire HD 4830
    X-Fi Xtreme Music
    Acer P221w and Acer 1916w
    1680x1050 and 1440x900
    Antec Earthwatts 500W
    Antec Sonata III
    Logitech G5 v2
    Logitech Wave
so true, if it is an hp motherboard, you can forget it.
    Garage PC
    BioStar G41-M7
    Realtek
    HP Mx705 (CRT)
    1152x864
    Stock Intel HSF
    Generic PS/2
    10 d / 1 u
