partition help, please
franny123
I am having all types of computer problems with this laptop, but the one which bothers me most is one of my partitions has disappeared. Of course, it is the one where I kept all my programs, etc. I can't access the D drive. The programs are still on the drive which is using all the disk space, and I can't reinstall to the C drive for I get the message the program is already installed. Is there anyway to get the D drive back intact? Thanks for any help you might could give me.
    HP Laptop 9600
    //tyruib
Hi, I looked at Microsoft Answers and came across this for assigning a drive letter.
Here’s how you can assign a drive letter using Windows interface. 1. Go to start and type diskmgmt.msc.
2. Select the partition for which you want to change the drive letter, right click on it and select Change Drive Letter and Paths from the right click menu.
3. You may choose “Add” or “Change” depending on whether drive letter is already assigned or not.
4. From the Assign the following drive letter drop down list, select the drive letter you want to assign and click on OK.
5. You will receive a warning stating that some programs might not run correctly if you change the drive letter. If you did not install any applications on that drive it should be OK to change it. Click on Yes and the drive letter change will be done.
If it goes unsuccessful, try using diskpart utility.
1. Go to start and type cmd.
2. Right-Click on Cmd and select “Run as Administrator”.
diskpart
3. At the DISKPART prompt, type:
list volume
Make note of the number of the simple volume whose drive letter you want to assign, change, or remove.
4. At the DISKPART prompt, type:
select volume n
Select the volume, where n is the volume's number, whose drive letter you want to assign, change, or remove.
5. At the DISKPART prompt, type one of the following:
assign letter=L
Where L is the drive letter you want to assign or change.
See if this helps you in restoring the drive.
Let us know how you get on.
Regards
Elton
    Windows 11 x2, Windows 10 x2
    PCS Custom desktop, HP OMEN 17, MS Surface Pro 6 and HP Pavillion 15
    Intel i7-4790, i7-8750, i5 and AMD-9420
    16GB, 16GB, 8GB and 8GB
    Nvidea GeForce GTX 750Ti, GTX1050Ti, on-board and on-board
    Dell U3415W
    3440x1440
    Too many to list!
    75MB/s
Thanks for the quick reply. My question is that the only other drive is C: which contains the windows vista and all updates. Will it be safe to rename this drive to D. None of the applications which were on D show up, but according to disk space they are still there somewhere. The drive D does not show up anymore. Just can see C drive.
    HP Laptop 9600
    //tyruib
Sorry if it isn't clear from my reply.
In Disc Management you will see Drive C and also an unallocated space that used to be occupied by Drive D. What the advice above is trying to do is not rename the C drive to D, but allocate D to the partition it once occupied. Sometimes this can be done without loosing the data. Have a look in Disk Management and report back what the how the Hard Disk Drive is structured.
Edit: I would not recommend changing C to D.
    Dell U3415W
    3440x1440
    Too many to list!
    75MB/s
To post screen shots:
http://www.vistax64.com/tutorials/289032-screenshots-files-upload-post-vista-forums.html
To open Disk Management
1. Open the Control Panel. (Classic View)
A) Click on the Administrative Tools icon.
B) Click on Computer Management.
2. Click on Continue in the UAC prompt.
3. In the left pane, click on Disk Management under Storage.
Maximize the Disk Management window.
Take a screen shot.
Upload it so we can see what's up.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
When I look up HP 9600 laptop it shows it as having 100 GB drive. That's what disk management shows. I don't see any unallocated space.
    HP Pavilion m9515y
    Phenom X4 9850
    CRT
Looking at your screen shot and MilesAhead's reply I have to concur that the drive has no unallocated space. If the software will not allow you to install again I suspect it has installed onto the C drive. What do you see in the Programs folder?
Also, what is the purpose of the 1GB Fran drive?
    Dell U3415W
    3440x1440
    Too many to list!
    75MB/s
The Fran Drive is used only for photoshop and 2 other photo editing programs. They all are large programs. On the drive which disappeared was all my documents, photos, music and word processors, and the like. These must be on drive c: for there is so much space used,. C drive should only have windows vista and updates and the other things that just go with windows. I am just about ready to format all and start over. Thanks for all the help. I dont mean to seem ungrateful--just discouraged.
    HP Laptop 9600
    //tyruib
Are you having trouble locating your files or running programs or are you just confused as to the drive letter? If everything is working there's no need to start over.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
I don't think it's a good idea to change your system disk driver letter...:confused:
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
For one, that applies to XP, 2000, & 2003 and not necessarily to Vista or 7. Two, I don't consider a registry hack valid to equivocate your statement that windows lets you change your drive letter after all you aren't asking it. Although I didn't imply it I was referring to attempting to do so through disk management. If you try it there you'll see that Windows won't let you (see below). Further more I don't recommend this.
    8 gb
    1 TB x2
    Dell Poweredge T140
    1 TB & 360 GB x2
