Partitioning a Flash Drive
Gudziel
    Intel Core2Duo E8400 3.0GHz
    eVGA NVIDIA nForce 780i SLI
    OCZ NVIDIA SLI-Ready Edition 4x2GB PC6400 DDR2800 4-4-4-15
    eVGA GeForce GTX 260 896MB GDDR3
    Creative Sound Blaster Audigy 7.1
    LG - 23" Widescreen Flat-Panel LCD HD Monitor - Black
    Seagate Barracuda 250GB 7200RPM SATA 3.0Gb/s
    OCZ GameXStream 600W
    Cooler Master HAF 932
    Arctic Cooling Freezer 7 Pro CPU Cooler, 6x120mm, 2x140mm
    Logitech G51 155 watts RMS 5.1 Surround Sound Speakers
Nevermind, I figured it out myself. I went to OCZ's official website, and under the downloads section they have a program you can download specifically for their flash drives (unsure if it is meant solely for the "Diesel" brands or Flash Drives in general). It's a lock program that will VERY easily allow you to adjust a slider to split into two partitions. One partition is automatically marked "secure", the other is "public". The lock program will also automatically place a version of the lock.exe file into the public file so you can access the secured partition with a PW you create yourself. I then used the TrueCrypt program that nso5300 had suggested I use. It is just going to take 2hrs to create the 3.5gb encrypted directory on the stick... lol
