PCI / USB driver problem
armydude
Everytime I restart my computer I get a bunch of "found new hardware" and its all my pci/usb devices. If i click "ask me later" it works fine and I can use the front usb ports on my CM Storm case. If i click "dont ask me again" they stop working completely. Note under Device Manager all these devices claim to be "This device is working properly"
Except I have 1 unknown device that says it hasent installed a driver yet and when I try to install it I get.
NVIDIA nForce PCI System Management
An error occurred during the installation of the device:
The driver installation file for this device is missing a necessary entry. This may be because the INF was written for Windows 95 or later. Contact your hardware vendor.
Lately my computer has been choking itself so ive been fixing anything I can find to help. Any support will be appreciated.
    AMD Phenom(tm) II x4 965
    m4n72-e
    NVIDIA Geforce GTS 450
    ACER AL2016W
    1680 x 1050
    465 GB
    CM STORM
    5 SickleFlow 120, 1 cpu water cooler.
    Logitech Wireless
Hello, have you installed all applicable Microsoft Updates ?
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Ive been installing any microsoft updates that appear with "Windows Update" on my computer. I went to Microsoft's site for help but their autofix program ended up giving me the same error after it found the driver aswell.
    m4n72-e
    ACER AL2016W
    1680 x 1050
    465 GB
    CM STORM
    Logitech Wireless
Have you made it up to SP2 yet ? I ask because you specs do not indicate Vista Home Prem 64 bit SP 2 . Just checking .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Im not entirely sure, what is the fastest way to check this?
EDIT** Yes i have sp2 installed.
    m4n72-e
    ACER AL2016W
    1680 x 1050
    465 GB
    CM STORM
    Logitech Wireless
Go to Start, Control Panel, System, open that up and see what it shows you as your OS .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Yes sp2 is installed, in my profile I listed all my specs for anything else.
    m4n72-e
    ACER AL2016W
    1680 x 1050
    465 GB
    CM STORM
    Logitech Wireless
K.. good .. In Device Manager , from your Start button , Control panel. Any yellow icons ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
WHen you open up the Tree ( plus sign ) and attempt update, does it still show latest driver is installed ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Only yellow icon is the one I listed in the first post, the "unknown device" that I can find the driver for but wont let me download the driver.
The drivers for this device are not installed. (Code 28)
The installation failed because a function driver was not specified for this device instance.
To reinstall the drivers for this device, click Reinstall Driver.
    m4n72-e
    ACER AL2016W
    1680 x 1050
    465 GB
    CM STORM
    Logitech Wireless
Do this for me please, right click that rascal , properties , and see what name of that driver is ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Under General
Device tpye: Other devices
Manufacturer: Unknown
Location PCI bus 0, device 1, function 1
Device status
Under Driver
Driver Provider: Unknown
Driver Date: N/A
Driver Version: N/A
Digital Signer: Not digitally signed
"Driver Details" say "No driver files are required or have been loaded for this device."
Under Details
Value
PCI\VEN_10DE&DEV_0752&SUBSYS_82E81043&REV_A1
PCI\VEN_10DE&DEV_0752&CC_0C0500
    m4n72-e
    ACER AL2016W
    1680 x 1050
    465 GB
    CM STORM
    Logitech Wireless
I betcha that all your stuff is working just fine tho, right ? Here is a thing i think you could check on tho. Go to the manufacture of said driver, Or at very least, the computer make and model number and get the latest version of your drivers, Download them and save . Then go to your Device Manager and go to the yellow icon, do the Update thing, but have it install/search from your computer files. Have it install that driver ,, only if it was one applicable. Do ya understand what i just typed? As , this is a situation that alot of user will see, but, even with latest drivers, some such things will just not work out. Give my idea a shot and let us/me know how this works out please.
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Okay thanks for the help i'll post here if I get it working. If not oh well.
    m4n72-e
    ACER AL2016W
    1680 x 1050
    465 GB
    CM STORM
    Logitech Wireless
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
