Solved Penway
penway
Since yesterday when I log into my windows mail account my ISP's (Talk Talk) server downloads every message on the server including ones that have been downloaded and read.
Has anyone else experienced and solved a similar issue - it's driving me mad.
I won't call this suggestion of mine as solution, at best its a " work-around ".....
Open WM > Tools > Accounts > your Talk Talk acct > Properties > Advanced >under Delivery heading, UN-check " Leave a copy of messages on server " > OK
  • Other Info
    WLM 2011 IE9 beta
While djch129's solution should pretty much solve the re-downloading problem, if you want the messages to remain on the server for some reason (perhaps if you want to read them online elsewhere but find nothing there because they were all downloaded to your running and on-line home computer and deleted so you need to wait until you get home to access them), then your best option is to contact TalkTalk technical support and report the problem.
It's probably a simple fix in the configuration of your e-mail program, your online email account, or on their servers (which is what I suspect) - in any event, I'm sure they can resolve the problem. They may already be aware of the problem and working to fix it as we type these messages. Contacting TalkTalk technical support is the first thing I'd do if that happened to me and so I suggest you give them a ring.
I hope this helps.
Good luck!
    1920 x 1200 pixels
Thanks Lorien, but I already called talk talk and they insisted that it wasn't their problem, but is something in windows mail, that microsoft should help with as they don't deal with windows mail problems.
Great customer service eh!
So still trying to resolve it myself. Currently setting up windows live mail a/c on a second pc to see whether the issue is present when I try that.
WLM is a much better product than Windows Mail. Are you using the Expressions 2011 version - that's the latest and greatest. I suppose there could be a setting in Windows Mail that tells it to download everything even if it has already been downloaded and read (though why anyone would want to do that is beyond me and I don't recall ever seeing such a setting but I may have overlooked it). I'll check to see if I can find such a setting in my version. In the meantime, I think you'll be happier with WLM and hopefully that will also clear up the problem - if not, we'll need to check those settings as well.
I wish you success. I'll let you know if I find anything.
Good luck!
    1920 x 1200 pixels
Thanks Lorien, and to update you I tried WLM on the other pc and it worked fine, so will now salvage what I can from my WM account and install WLM on the main one and import to that. In the meantime all my messages that were left on the server have disappeared, from it, so can only assume that TalkTalk have been responsible despite their assurance to the contrary.
Very grateful for your help, and knowledge, and you're right - WLM is much superior to WM.
I'm happy to hear that your problem is resolved and you're happy with the upgraded product as well. It was our pleasure to assist - glad we could help in any way.
Thank you for the feedback - it is appreciated.
Don't forget to close out the thread by clicking the far right triangular icon at the top of your post and typing "solved" in the box and submitting it. The moderators will notice and put a green check next to the thread title. That way others seeking answers by searching the forums will know that this thread contains a solution to the issue identified in the title - and people seeking to help will not waste time checking out this thread since it has been resolved.
And welcome to Vista Forums! Now that you know where we are, bookmark the site and post anytime you have further questions or problems or if you just want to browse and learn (especially the Tutorial section offers some excellent advice on a wide variety of topics) or even if you want to try to help answer a question if you happen to see one where you know the answer and it hasn't already been posted. While it most likely won't be me the next time (though it might), there are many very skilled, experienced, knowledgeable, and friendly people here who, like me, volunteer their time to help others and one or maybe even several will respond to your post to assist you. While there are other forums on the web that do this sort of thing, you've now found what I think is the best (and I've posted in and/or checked out quite a few) so don't lose this link - you never know when it might come in handy again.
Good luck and best wishes.
    1920 x 1200 pixels
