please help thank you
veryunhappy
hi all
i keep getting this on start up can someone tell me what it is and how do i get rid of it please
c:\windows\system32\msupdte.exe
the NTVDM CPU has encounted an illegal instruction
CS:11f1 IP:024e OP:63 72 69 70 74 Choose 'Close to terminatethe application
all help would be nice as this is doing my head in
thankyou
From a quick google it suggests that it's a trojan, what antivirus software do you have installed?
    Windows 11 Workstation
    Ryzen 9 5950X
    Creative
    1500W ThermalTake Toughpower
    ThermalTake Level 10 GT
    Enermax Liqtech 240
    Logitech Performance MX
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
I would uninstal norton (as its crap) then install avast and do a full scan.
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
hi all
thankyou
msupdte.exe - Dangerous High Level Trojan
I suggest you to remove msupdte.exe from your computer as soon as possible.
Msupdte.exe is Trojan/Backdoor Access.
Kill the process msupdte.exe and remove msupdte.exe from Windows startup.
Also run a full scan with Avast to be downloaded from here: FREE avast! antivirus 4.x Home Edition, anti-spyware & anti-rootkit for Windows and best of all its Free ;)
Steven
Norton has a reputation as being one of the most burdensome antivirus programs (it slows down your PC). Some of the free ones have a better detection rate and are also less of a performance drag.
Seems Norton even missed your msupdte.exe which is a known malware and should be in any decent antivirus program's database by now.
I think the free versions of Avira Antivir or Avast are better for the home user.
    home assembled
    Intel Q9450 quad core
    Asus P5Q Pro, Intel P45 chipset
    4GB : 2 x 2GB G.Skill DDR2 800MHz
    Gigabyte 9600GT
    Realtek onboard the mobo
    BenQ 24"
    1920 x 1200
    2 of Samsung HD501LJ SATA2 500GB and a few IDE hard disks on USB for backups
    Corsair TX-650 and APC UPS
    Antec P180
    OCZ Vendetta2
Just load it up and let it do a scan, it should do the rest for you ;)
    Ryzen 9 5950X
    Creative
    Enermax Liqtech 240
    Surface Ergonomic.
    350 Mb/s
    windows 10
    Surface Pro 3
    12" Multi Touch
    2160 x 144
    128GB
    yes
    350 Mb/s
Do a thorough scan. And make sure nothing is unchecked in the scanning list. Especially the registry entries.
    T4200 Intel
    2 X 1GB DDR2
    Intel Integrated
    1 X 250GB 7200RPM
try this online scanner/cleaner too
Eset NOD32
    T7600G Core2Duo 2.66 Ghz
    Intel 945PM + ICH7 Chipset
    4GB DDR2 PC2-5300 667MHz
    Mobility Radeon x1900 256MB
    Realtek HD
    WUXGA 17"
    1920X1200
    Wireless Microsoft 3000
    10 mbps/2 mbps
Right click the blue ball in the notification area with an a in it. Click Start Avast antivirus. Tick all 5 boxes ( if you don't have a floppy - obviously don't need to tick that one ) including Test Archives. Left click the slider and drag it to Thorough - clck start scan. ( Make sure you update it before scanning - rt click it and select iAvs update ).
It's worth checking with a few other free tools afterwards as well,
try a-squared 3.5 Free , download it from
http://www.emsisoft.com/en/software/download/
Hope this helps
SIW2
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
run smitfraudfix. select the 2nd, 4th and then 5th option to clean your computer. download link:
http://siri.urz.free.fr/Fix/SmitfraudFix.exe
Note: uninstall all the antivirus software before installing smitfraudfix.
It works as a charm and removes almost all the types of virus, adwares, malwares and spywares.
    Compaq
    intel 965 chipset family
    2 GB DDR 2 SD RAM @ 667 MHz
    On board upto 358 MB RAM
    15"
    160 GB WDC
