please help
sitruc
help im trying to fix my moms windows xp media center edition 2005 laptop and it has the ntdetect failed thing on it and she doesnt have the boot cd's. she also has importent files on there that she cant lose. PLEASE HELP ME!!!!!!
    toshiba satellite L305-S5921
    2.16GHz
    portable pc
    2.00 gb
    idk
    realtek high definition audio
    876GB(external hard drive) 150GB(main hard drive)
    Vista
    Intel E8400
    ASRock1333-GLAN R2.0
    4gb DDR2 800
    nvidia 9500GT 1gb
    win7/vista
    intel i5-8400
    gigabyte b365m ds3h
    ballistix 2x8gb 3200
    2.16GHz
    portable pc
    2.00 gb
    idk
One thing you can try is to open it up and make sure everything is tight.
Looks like the bios is not detecting the drive or windows.
Either you have a bad drive or windows is missing the boot thing.
Did a google search and found this Error Message Detail
Jimmy
    Gateway
    intel core 2 Extreme QX6700
    intel
    3 gigs
    NVIDA
    Creative SB X-FI
    Gateway 24 HD Monitor
    1920 by 1200 pixels
    2-500 gigabyte hard drive Western digtal
best thing to do.. just to simplify it is to remove the hard drive off the laptop.. connect it externally to another computer.. retrieve all the important files etc.. then format and reinstall windows on the laptop..
If you want more help to carry on this step.. let us know..
cheers
