Solved please help
hackdot
all my icons and files are now .ink and i cant start half the ****....
a friend tried to send me a pic of her and it didnt work i tried to open with windows gallary etc...and it didnt work then she changed the pic and resent then work
then 2 mins later i look and all the desktop icons are all ****ed up
Hello and wlecome to the forum.
Do a system restore this way you don't lose any of you documents etc. This is how...
http://www.vistax64.com/tutorials/194765-system-recovery-options.html
http://www.vistax64.com/tutorials/66971-system-restore.html
Please don't worry, doing a system restore is not like a factory restore, this is easy to do, go back say 2 to 3 days before this happened and you will be fine if you need more help post back here in this thread and we will help you. Please print the instructions before performing the restore so you can follow along.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
Thats great would you share you story as how you fixed your system so that others in the same positon would be helped by your thread.
Thank You
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
