pls help thx
Tarak
Hi
I was just re-installing vista
and it asked me for the product key
I used the one at the bottom of my laptop which i have never used before
It showed me it is invalid.
What to do?
my 2nd question:
can i go to control panel --> system--> and there it shows my the product ID
Can i use that instead??????????
THX A LOT
Hi
What to do?
my 2nd question:
THX A LOT
No you can't use the product ID to activate.
Make sure you typed the product key correctly.
Try using the automated phone activation service (if available).
If not contact Microsoft and ask for them to give you a new product key.
Oli
    Apple MacBook, 5,1
    Intel Core 2 Duo 2.4Ghz
    4GB DDR3
    Nvidia 9400m
    13.3" Apple MacBook LCD Screen + 22" HannsG DVI LCD + 21.5" Samsung USB Lapfit Monitor LD220
    1280x800 + 1920x1080 + 1920x1080
    SATA Internal 2.5" 500GB (305GB HFS+, 195GB NTFS) External USB 3.5" 1TB (HFS+)
    Aluminium Unibody
    Apple Magic Mouse
    Apple Late 2009 Wireless Keyboard (US)
    6.33Mb/s up. 0.36Mb/s down.
    Harman Kardon Soundsticks II Speakers
can i use keyfinder?
I it's not activated no.
Even on the old installation no because that came with a one activation key that was from the factory install.
Oli
    Apple MacBook, 5,1
    4GB DDR3
    Nvidia 9400m
    Aluminium Unibody
    Apple Magic Mouse
