Hi, I posted a short time ago about Spooler sub system app has stopped working,
went through the reply i recived Adminstrive tools but that didn't cure it.
The problem becomes a bind every time you start up & the message shows up
the solution they give does not seem to cure it. to select the proggrammes that the spooler should manage. My printer is a Lexmark x1270, any idea's how i can get rid of this problem? would be appreciated. Thanks.
Hi Rich did manage to reinstall the printer but same problem started again can i uninstall the print spooler & reinstall it? Thanks
