Problem Event Name: BlueScreen
Hello!
I am a new Vista user and when I woke up this morning this was going on. Can someone please help me resolve this issue.
I appreciate your swift action. When I bring it up in safe mode and ask for the prompt to find solutions, nothing happens.
Thanks!
Problem signature
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 14337
Files that help describe the problem (some files may no longer be available)
Mini083010-01.dmp
sysdata.xml
Version.txt
View a temporary copy of these filesWarning: If a virus or other security threat caused the problem, opening a copy of the files could harm your computer.
Extra information about the problem
BCCode: d1
BCP1: 00000000
BCP2: 00000002
BCP3: 00000000
BCP4: 8E705705
OS Version: 6_0_6002
Service Pack: 2_0
Product: 768_1
Sorry that it took so long to respond, but with the vacation season, many regulars have not reported: making response time longer.
STOP 0x000000D1: DRIVER_IRQL_NOT_LESS_OR_EQUAL Usual causes: Device driver
STOP 0x0000004E: PFN_LIST_CORRUPT Usual causes: Device driver, ?memory
Code:
icrosoft (R) Windows Debugger Version 6.11.0001.404 AMD64
Loading Dump File [C:\Users\richc46\AppData\Local\Temp\Temp3_Windows_NT6_BSOD_jcgriff2[1].zip\Windows_NT6_BSOD_jcgriff2\Mini083010-01.dmp]
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows Server 2008/Windows Vista Kernel Version 6002 (Service Pack 2) MP (2 procs) Free x86 compatible
Built by: 6002.18267.x86fre.vistasp2_gdr.100608-0458
Machine Name:
Kernel base = 0x82246000 PsLoadedModuleList = 0x8235dc70
Debug session time: Mon Aug 30 15:16:44.617 2010 (GMT-4)
System Uptime: 0 days 6:04:29.695
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
BugCheck D1, {0, 2, 0, 8e705705}
Probably caused by : USBPORT.SYS ( USBPORT!USBPORT_DereferenceDeviceHandle+a1 )
Followup: MachineOwner
0: kd> !analyze -v
DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)
An attempt was made to access a pageable (or completely invalid) address at an
interrupt request level (IRQL) that is too high.  This is usually
caused by drivers using improper addresses.
If kernel debugger is available get stack backtrace.
Arguments:
Arg1: 00000000, memory referenced
Arg2: 00000002, IRQL
Arg3: 00000000, value 0 = read operation, 1 = write operation
Arg4: 8e705705, address which referenced memory
Debugging Details:
READ_ADDRESS: GetPointerFromAddress: unable to read from 8237d868
Unable to read MiSystemVaType memory at 8235d420
 00000000
CURRENT_IRQL:  2
FAULTING_IP:
8e705705 ff37            push    dword ptr [edi]
CUSTOMER_CRASH_COUNT:  1
DEFAULT_BUCKET_ID:  VISTA_DRIVER_FAULT
BUGCHECK_STR:  0xD1
PROCESS_NAME:  ServiceLayer.ex
TRAP_FRAME:  8039de28 -- (.trap 0xffffffff8039de28)
ErrCode = 00000000
eax=54627255 ebx=87113028 ecx=871c1000 edx=00000000 esi=871130e8 edi=00000000
eip=8e705705 esp=8039de9c ebp=8039deb8 iopl=0         nv up ei ng nz na pe nc
cs=0008  ss=0010  ds=0023  es=0023  fs=0030  gs=0000             efl=00010286
USBPORT!USBPORT_DereferenceDeviceHandle+0xa1:
8e705705 ff37            push    dword ptr [edi]      ds:0023:00000000=????????
Resetting default scope
LAST_CONTROL_TRANSFER:  from 8e705705 to 82293fd9
STACK_TEXT:
8039de28 8e705705 badb0d00 00000000 00000003 nt!KiTrap0E+0x2e1
8039deb8 8e709df4 02113028 2b667264 af7feb84 USBPORT!USBPORT_DereferenceDeviceHandle+0xa1
8039df04 8e708132 87113028 a1920b40 a193fb30 USBPORT!USBPORT_Core_iCompleteDoneTransfer+0x6b5
8039df34 8e70a95f 87113028 39585043 87113bf8 USBPORT!USBPORT_Core_iIrpCsqCompleteDoneTransfer+0x4f5
8039df60 8e70424f 87113028 87113bf8 87113002 USBPORT!USBPORT_Core_UsbIocDpc_Worker+0x122
8039df88 822f06c2 87113c04 34776478 00000000 USBPORT!USBPORT_Xdpc_Worker+0x274
8039dff4 822ee2f5 90ae3c9c 00000000 00000000 nt!KiRetireDpcList+0x147
8039dff8 90ae3c9c 00000000 00000000 00000000 nt!KiDispatchInterrupt+0x45
WARNING: Frame IP not in any known module. Following frames may be wrong.
822ee2f5 00000000 0000001b 00c7850f bb830000 0x90ae3c9c
STACK_COMMAND:  kb
FOLLOWUP_IP:
SYMBOL_STACK_INDEX:  1
SYMBOL_NAME:  USBPORT!USBPORT_DereferenceDeviceHandle+a1
FOLLOWUP_NAME:  MachineOwner
MODULE_NAME: USBPORT
IMAGE_NAME:  USBPORT.SYS
DEBUG_FLR_IMAGE_TIMESTAMP:  49e01fcf
FAILURE_BUCKET_ID:  0xD1_USBPORT!USBPORT_DereferenceDeviceHandle+a1
0: kd> lmtsmn
start    end        module name
a6720000 a6741000   000      000.fcl      Thu Jan 24 06:14:00 2008 (479872F8)
80691000 806d7000   acpi     acpi.sys     Sat Apr 11 00:19:03 2009 (49E01A37)
91972000 919ba000   afd      afd.sys      Sat Apr 11 00:47:01 2009 (49E020C5)
8a151000 8a159d00   AlfaFF   AlfaFF.sys   Tue Nov 06 11:37:11 2007 (47309837)
8a0e0000 8a0e8000   atapi    atapi.sys    Sat Jan 19 00:49:40 2008 (47918F74)
8a0e8000 8a106000   ataport  ataport.SYS  Sat Jan 19 00:49:40 2008 (47918F74)
99920000 9996c000   ATMFD    ATMFD.DLL    unavailable (00000000)
80721000 8072b000   BATTC    BATTC.SYS    Sat Jan 19 00:32:45 2008 (47918B7D)
8fff6000 8fffd000   Beep     Beep.SYS     Sat Jan 19 00:49:10 2008 (47918F56)
80494000 8049c000   BOOTVID  BOOTVID.dll  Sat Jan 19 02:27:15 2008 (4791A653)
a128d000 a12a6000   bowser   bowser.sys   Sat Jan 19 00:28:26 2008 (47918A7A)
99910000 9991e000   cdd      cdd.dll      unavailable (00000000)
91a9d000 91ab3000   cdfs     cdfs.sys     Sat Jan 19 00:28:02 2008 (47918A62)
8e7db000 8e7f3000   cdrom    cdrom.sys    Sat Apr 11 00:39:17 2009 (49E01EF5)
804dd000 805bd000   CI       CI.dll       Sat Apr 11 02:25:22 2009 (49E037D2)
8a5a3000 8a5c4000   CLASSPNP CLASSPNP.SYS Sat Apr 11 00:39:05 2009 (49E01EE9)
8049c000 804dd000   CLFS     CLFS.SYS     Sat Apr 11 00:13:51 2009 (49E018FF)
8e6f4000 8e6f7780   CmBatt   CmBatt.sys   Sat Jan 19 00:32:47 2008 (47918B7F)
8071e000 80720900   compbatt compbatt.sys Sat Jan 19 00:32:47 2008 (47918B7F)
91ab3000 91ac0000   crashdmp crashdmp.sys Sat Apr 11 00:39:12 2009 (49E01EF0)
8a5c4000 8a5cd000   crcdisk  crcdisk.sys  Sat Jan 19 00:50:29 2008 (47918FA5)
91a7b000 91a92000   dfsc     dfsc.sys     Sat Apr 11 00:14:12 2009 (49E01914)
8a592000 8a5a3000   disk     disk.sys     Sat Apr 11 00:39:14 2009 (49E01EF2)
8f5c9000 8f5d3000   DKbFltr  DKbFltr.sys  Thu Oct 19 04:24:28 2006 (4537363C)
8fe3d000 8fe62000   drmk     drmk.sys     Sat Jan 19 01:53:02 2008 (47919E4E)
91ac0000 91b99000   dump_iaStor dump_iaStor.sys Sun Jul 20 20:15:55 2008 (4883D53B)
91b99000 91ba3000   Dxapi    Dxapi.sys    Sat Jan 19 00:36:12 2008 (47918C4C)
8f141000 8f1e2000   dxgkrnl  dxgkrnl.sys  Thu Sep 24 21:27:14 2009 (4ABC1C72)
8a56b000 8a592000   ecache   ecache.sys   Sat Apr 11 00:40:12 2009 (49E01F2C)
a678b000 a67b3000   fastfat  fastfat.SYS  Sat Apr 11 00:13:52 2009 (49E01900)
8a138000 8a148000   fileinfo fileinfo.sys Sat Jan 19 00:34:27 2008 (47918BE3)
8a106000 8a138000   fltmgr   fltmgr.sys   Sat Apr 11 00:13:59 2009 (49E01907)
8ffe6000 8ffef000   Fs_Rec   Fs_Rec.SYS   Sat Jan 19 00:27:57 2008 (47918A5D)
918f2000 9190d000   fwpkclnt fwpkclnt.sys Sat Apr 11 00:45:42 2009 (49E02076)
82213000 82246000   hal      halmacpi.dll Sat Apr 11 00:13:13 2009 (49E018D9)
8e74e000 8e7db000   HDAudBus HDAudBus.sys Sat Apr 11 00:42:41 2009 (49E01FC1)
8fc00000 8fc06380   HIDPARSE HIDPARSE.SYS Sat Jan 19 00:53:16 2008 (4791904C)
8f892000 8f947000   HSX_CNXT HSX_CNXT.sys Tue Mar 25 18:38:29 2008 (47E97EE5)
8fe9f000 8ffa1000   HSX_DPV  HSX_DPV.sys  Tue Mar 25 18:41:22 2008 (47E97F92)
8fe62000 8fe9f000   HSXHWAZL HSXHWAZL.sys Tue Mar 25 18:39:19 2008 (47E97F17)
a1203000 a1270000   HTTP     HTTP.sys     Sat Feb 20 15:53:31 2010 (4B804BCB)
8f5b6000 8f5c9000   i8042prt i8042prt.sys Sat Jan 19 00:49:17 2008 (47918F5D)
8a007000 8a0e0000   iaStor   iaStor.sys   Sun Jul 20 20:15:55 2008 (4883D53B)
a13c1000 a13d2000   int15    int15.sys    Wed Oct 01 01:29:49 2003 (3F7A664D)
8a5da000 8a5e9000   intelppm intelppm.sys Sat Jan 19 00:27:20 2008 (47918A38)
9194c000 9195e000   ipfltdrv ipfltdrv.sys Sat Jan 19 00:56:23 2008 (47919107)
8f5d3000 8f5de000   kbdclass kbdclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
8040c000 80413000   kdcom    kdcom.dll    Sat Apr 11 02:25:29 2009 (49E037D9)
8f80b000 8f835000   ks       ks.sys       Sat Apr 11 00:38:47 2009 (49E01ED7)
8a15a000 8a1cb000   ksecdd   ksecdd.sys   Mon Jun 15 08:48:53 2009 (4A364335)
8f591000 8f5a1000   L1E60x86 L1E60x86.sys Tue May 20 03:23:06 2008 (48327C5A)
91bcd000 91bdd000   lltdio   lltdio.sys   Sat Jan 19 00:55:03 2008 (479190B7)
91bb2000 91bcd000   luafv    luafv.sys    Sat Jan 19 00:30:35 2008 (47918AFB)
805bd000 805d9800   mcdbus   mcdbus.sys   Tue Feb 24 05:42:13 2009 (49A3CF05)
80413000 80483000   mcupdate_GenuineIntel mcupdate_GenuineIntel.dll Sat Apr 11 02:23:19 2009 (49E03757)
a13d2000 a13d5180   mdmxsdk  mdmxsdk.sys  Mon Jun 19 17:26:59 2006 (449716A3)
a6741000 a6752b80   mfeavfk  mfeavfk.sys  Sat Oct 11 17:49:26 2008 (48F11F66)
a6705000 a670bf80   mfebopk  mfebopk.sys  Sat Oct 11 17:50:11 2008 (48F11F93)
91a48000 91a7a840   mfehidk  mfehidk.sys  Sat Oct 11 17:46:49 2008 (48F11EC9)
a6753000 a675b420   mfesmfk  mfesmfk.sys  Sat Oct 11 17:52:06 2008 (48F12006)
8ffa1000 8ffae000   modem    modem.sys    Sat Jan 19 00:57:16 2008 (4791913C)
a67da000 a67e9000   monitor  monitor.sys  Sat Jan 19 00:52:19 2008 (47919013)
8f5e0000 8f5eb000   mouclass mouclass.sys Sat Jan 19 00:49:14 2008 (47918F5A)
80784000 80794000   mountmgr mountmgr.sys Sat Jan 19 00:49:13 2008 (47918F59)
9190d000 91936000   Mpfp     Mpfp.sys     Mon Jun 02 16:56:00 2008 (48445E60)
a12a6000 a12bb000   mpsdrv   mpsdrv.sys   Sat Jan 19 00:54:45 2008 (479190A5)
a12bb000 a12dc000   mrxdav   mrxdav.sys   Sat Apr 11 00:14:39 2009 (49E0192F)
a12dc000 a12fb000   mrxsmb   mrxsmb.sys   Tue Feb 23 06:10:12 2010 (4B83B794)
a12fb000 a1334000   mrxsmb10 mrxsmb10.sys Tue Feb 23 06:10:17 2010 (4B83B799)
a1334000 a134c000   mrxsmb20 mrxsmb20.sys Tue Feb 23 06:10:12 2010 (4B83B794)
8f9ae000 8f9b9000   Msfs     Msfs.SYS     Sat Jan 19 00:28:08 2008 (47918A68)
806e0000 806e8000   msisadrv msisadrv.sys Sat Jan 19 00:32:51 2008 (47918B83)
8a3a1000 8a3d0000   msiscsi  msiscsi.sys  Sat Apr 11 00:40:07 2009 (49E01F27)
8a30b000 8a336000   msrpc    msrpc.sys    Sat Apr 11 00:37:32 2009 (49E01E8C)
8f835000 8f83f000   mssmbios mssmbios.sys Sat Jan 19 00:32:55 2008 (47918B87)
8a55c000 8a56b000   mup      mup.sys      Sat Apr 11 00:14:12 2009 (49E01914)
8a200000 8a30b000   ndis     ndis.sys     Sat Apr 11 00:45:52 2009 (49E02080)
8ea00000 8ea0b000   ndistapi ndistapi.sys Sat Jan 19 00:56:24 2008 (47919108)
91bdd000 91be7000   ndisuio  ndisuio.sys  Sat Jan 19 00:55:40 2008 (479190DC)
8a3d0000 8a3f3000   ndiswan  ndiswan.sys  Sat Apr 11 00:46:31 2009 (49E020A7)
8f881000 8f892000   NDProxy  NDProxy.SYS  Sat Jan 19 00:56:28 2008 (4791910C)
919ec000 919fa000   netbios  netbios.sys  Sat Jan 19 00:55:45 2008 (479190E1)
919ba000 919ec000   netbt    netbt.sys    Sat Apr 11 00:45:35 2009 (49E0206F)
8a336000 8a371000   NETIO    NETIO.SYS    Sat Apr 11 00:46:21 2009 (49E0209D)
8f20a000 8f591000   NETw5v32 NETw5v32.sys Mon Apr 28 09:29:22 2008 (4815D132)
8f9b9000 8f9c7000   Npfs     Npfs.SYS     Sat Apr 11 00:14:01 2009 (49E01909)
91a3e000 91a48000   nsiproxy nsiproxy.sys Sat Jan 19 00:55:50 2008 (479190E6)
82246000 825ff000   nt       ntkrpamp.exe Tue Jun 08 10:36:44 2010 (4C0E557C)
8a40b000 8a51b000   Ntfs     Ntfs.sys     Sat Apr 11 00:14:34 2009 (49E0192A)
8f5eb000 8f5f3000   NTIDrvr  NTIDrvr.sys  Wed Jan 30 20:30:42 2008 (47A124C2)
a13d6000 a13f3e00   NTIPPKernel NTIPPKernel.sys Tue Nov 13 08:21:34 2007 (4739A4DE)
8ffef000 8fff6000   Null     Null.SYS     Sat Jan 19 00:49:12 2008 (47918F58)
8ffae000 8ffbc000   nvhda32v nvhda32v.sys Wed Jun 25 16:04:44 2008 (4862A4DC)
8ea0e000 8f1403e0   nvlddmkm nvlddmkm.sys Sat Jul 19 05:08:55 2008 (4881AF27)
8e6b0000 8e6da000   nwifi    nwifi.sys    Sat Apr 11 00:43:27 2009 (49E01FEF)
8f9d0000 8f9e6000   pacer    pacer.sys    Sat Apr 11 00:45:51 2009 (49E0207F)
8070f000 8071e000   partmgr  partmgr.sys  Sat Apr 11 00:39:19 2009 (49E01EF7)
806e8000 8070f000   pci      pci.sys      Sat Apr 11 00:19:16 2009 (49E01A44)
a6602000 a66e0000   peauth   peauth.sys   Mon Oct 23 04:55:32 2006 (453C8384)
8fe10000 8fe3d000   portcls  portcls.sys  Sat Apr 11 00:42:48 2009 (49E01FC8)
8a148000 8a151000   psdfilter psdfilter.sys Mon Feb 18 08:49:54 2008 (47B98D02)
a66e0000 a66e9000   PSDNServ PSDNServ.sys Mon Feb 18 08:50:35 2008 (47B98D2B)
a66e9000 a66fb000   PSDVdisk PSDVdisk.sys Mon Feb 18 08:50:56 2008 (47B98D40)
80483000 80494000   PSHED    PSHED.dll    Sat Apr 11 02:25:32 2009 (49E037DC)
8f9c7000 8f9d0000   rasacd   rasacd.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8a5e9000 8a600000   rasl2tp  rasl2tp.sys  Sat Jan 19 00:56:33 2008 (47919111)
8a1cb000 8a1da000   raspppoe raspppoe.sys Sat Apr 11 00:46:30 2009 (49E020A6)
8a1da000 8a1ee000   raspptp  raspptp.sys  Sat Jan 19 00:56:34 2008 (47919112)
807dd000 807f2000   rassstp  rassstp.sys  Sat Apr 11 00:46:40 2009 (49E020B0)
91a02000 91a3e000   rdbss    rdbss.sys    Sat Apr 11 00:14:26 2009 (49E01922)
8f99e000 8f9a6000   RDPCDD   RDPCDD.sys   Sat Jan 19 01:01:08 2008 (47919224)
8f9a6000 8f9ae000   rdpencdd rdpencdd.sys Sat Jan 19 01:01:09 2008 (47919225)
91be7000 91bfa000   rspndr   rspndr.sys   Sat Jan 19 00:55:03 2008 (479190B7)
8fc08000 8fe0fc80   RTKVHDA  RTKVHDA.sys  Wed May 07 07:22:33 2008 (482190F9)
8ffbc000 8ffcf000   RTSTOR   RTSTOR.SYS   Tue Mar 25 22:59:10 2008 (47E9BBFE)
805da000 80600000   SCSIPORT SCSIPORT.SYS Sat Jan 19 00:49:44 2008 (47918F78)
a66fb000 a6705000   secdrv   secdrv.SYS   Wed Sep 13 09:18:32 2006 (45080528)
9195e000 91972000   smb      smb.sys      Sat Apr 11 00:45:22 2009 (49E02062)
8a554000 8a55c000   spldr    spldr.sys    Thu Jun 21 20:29:17 2007 (467B17DD)
8e600000 8e6b0000   spsys    spsys.sys    Tue Mar 10 13:10:28 2009 (49B69F04)
a1373000 a13c1000   srv      srv.sys      Fri Jun 18 11:04:55 2010 (4C1B8B17)
a134c000 a1373000   srv2     srv2.sys     Fri Jun 18 11:04:43 2010 (4C1B8B0B)
a1270000 a128d000   srvnet   srvnet.sys   Fri Dec 11 06:43:10 2009 (4B22304E)
8079c000 807dd000   storport storport.sys Sat Apr 11 00:39:19 2009 (49E01EF7)
8f5fe000 8f5ff380   swenum   swenum.sys   Sat Jan 19 00:49:20 2008 (47918F60)
8a371000 8a3a0100   SynTP    SynTP.sys    Fri Apr 25 12:18:01 2008 (48120439)
91808000 918f2000   tcpip    tcpip.sys    Wed Jun 16 09:45:41 2010 (4C18D585)
a670c000 a6718000   tcpipreg tcpipreg.sys Tue Dec 08 12:26:18 2009 (4B1E8C3A)
a67e9000 a67f3b80   tcusb    tcusb.sys    Tue Jan 29 21:45:37 2008 (479FE4D1)
8f5f3000 8f5fe000   TDI      TDI.SYS      Sat Jan 19 00:57:10 2008 (47919136)
91936000 9194c000   tdx      tdx.sys      Sat Apr 11 00:45:56 2009 (49E02084)
8a1ee000 8a1fe000   termdd   termdd.sys   Sat Apr 11 00:51:14 2009 (49E021C2)
998f0000 998f9000   TSDDD    TSDDD.dll    Sat Jan 19 01:01:09 2008 (47919225)
8e6eb000 8e6f4000   tunmp    tunmp.sys    Sat Jan 19 00:55:40 2008 (479190DC)
8e6e0000 8e6eb000   tunnel   tunnel.sys   Thu Feb 18 06:28:13 2010 (4B7D244D)
80794000 8079c000   UBHelper UBHelper.sys Wed Jan 30 20:30:26 2008 (47A124B2)
8f83f000 8f84c000   umbus    umbus.sys    Sat Jan 19 00:53:40 2008 (47919064)
8ffcf000 8ffe6000   usbccgp  usbccgp.sys  Sat Jan 19 00:53:29 2008 (47919059)
8f5de000 8f5df700   USBD     USBD.SYS     Sat Jan 19 00:53:17 2008 (4791904D)
8e73f000 8e74e000   usbehci  usbehci.sys  Sat Apr 11 00:42:52 2009 (49E01FCC)
8f84c000 8f881000   usbhub   usbhub.sys   Sat Apr 11 00:43:14 2009 (49E01FE2)
8e701000 8e73f000   USBPORT  USBPORT.SYS  Sat Apr 11 00:42:55 2009 (49E01FCF)
8f1ee000 8f1f9000   usbuhci  usbuhci.sys  Sat Jan 19 00:53:20 2008 (47919050)
8f947000 8f967b80   usbvideo usbvideo.sys Sat Jan 19 00:53:38 2008 (47919062)
8f971000 8f97d000   vga      vga.sys      Sat Jan 19 00:52:06 2008 (47919006)
8f97d000 8f99e000   VIDEOPRT VIDEOPRT.SYS Sat Jan 19 00:52:10 2008 (4791900A)
8072b000 8073a000   volmgr   volmgr.sys   Sat Jan 19 00:49:51 2008 (47918F7F)
8073a000 80784000   volmgrx  volmgrx.sys  Sat Apr 11 00:39:25 2009 (49E01EFD)
8a51b000 8a554000   volsnap  volsnap.sys  Sat Apr 11 00:39:37 2009 (49E01F09)
8f9e6000 8f9f9000   wanarp   wanarp.sys   Sat Jan 19 00:56:31 2008 (4791910F)
8f1e2000 8f1ee000   watchdog watchdog.sys Sat Apr 11 00:22:43 2009 (49E01B13)
80608000 80684000   Wdf01000 Wdf01000.sys Sat Jan 19 00:52:21 2008 (47919015)
80684000 80691000   WDFLDR   WDFLDR.SYS   Sat Jan 19 00:52:19 2008 (47919013)
996d0000 998d3000   win32k   win32k.sys   Mon Jun 21 09:36:50 2010 (4C1F6AF2)
8f5a1000 8f5b6000   winbondcir winbondcir.sys Wed Mar 28 01:51:32 2007 (460A0264)
8e6f8000 8e701000   wmiacpi  wmiacpi.sys  Sat Jan 19 00:32:47 2008 (47918B7F)
806d7000 806e0000   WMILIB   WMILIB.SYS   Sat Jan 19 00:53:08 2008 (47919044)
a6718000 a6720000   xaudio   xaudio.sys   Thu Oct 18 18:36:53 2007 (4717E005)
Unloaded modules:
a676b000 a6776000   tcusb.sys
    Timestamp: unavailable (00000000)
    Checksum:  00000000
a675c000 a676b000   monitor.sys
    Checksum:  00000000
a67c8000 a67da000   WUDFPf.sys
    Checksum:  00000000
a67b3000 a67c8000   WUDFRd.sys
    Checksum:  00000000
a6776000 a678b000   USBSTOR.SYS
    Checksum:  00000000
91a92000 91a9d000   tcusb.sys
    Checksum:  00000000
91ba3000 91bb2000   monitor.sys
    Checksum:  00000000
8a5cd000 8a5da000   crashdmp.sys
    Checksum:  00000000
8e607000 8e6e0000   dump_iaStor.
    Checksum:  00000000
8f968000 8f971000   kbdhid.sys
    Checksum:  00000000
Outdated Drivers
Code:
You have given me about 10 reports, Approximately 4 indicated a problem with usbport.sys a driver mfg by Microsoft
Another 4 indicated a problem with usbuhci.sys, a related driver, also manufacturerd by MS.
A final report indicated at network problem showing an intel driver as the cause
NETw5v32.sys Intel
Solution
Based upon these reports it is my opinion that you have a driver problem, specifically connected with your computer ports. A second less likely scenario is that the driver problem was caused by memory and finally that networking could be instrumental in causing the BSOD. It is my feeling that we have to concentrate on the port problem. To rectify the problem here are my suggestions, which should be done in the order given and the computer tested after each step to ascertain if the problem has been corrected.
Corrective Action Required
Remove all hardware that is connected to your computer ports, including modems etc (for test) except the mouse and keyboard.
Perform this scan . If errors are found run several times until corrections are no longer made.
If you have any third party Antivirus / Firewall uninstall it and see whether that makes any difference. Repalce with Microsoft Security Essentials (at least for test purposes) If your Overclocking please stop doing. You should replace with Microsoft Security Essentials, if the AV is indeed the problem
Scan with your AntiVirus
Uninstall and install the most current intel driver.
You have many outdated drivers. Update everything with a date prior to 1/08. If the BSODs are not resolved, I will suggest a driver verifier test to determine which are actually bad. Any Microsoft Drivers need not be updated at this point
Check with your vendor and see whether you have any latest BIOS Firmware updates. This is how.
How to Find Drivers
search Google for the name of the driver
- compare the Google results with what's installed on your system to figure out which device/program it belongs to
- visit the web site of the manufacturer of the hardware/program to get the latest drivers (DON'T use Windows Update or the Update driver function of Device Manager).
- if there are difficulties in locating them, post back with questions and someone - will help you search Google for the name of the driver
- - if there are difficulties in locating them, post back with questions and someone will try and help you locate the appropriate program.
- - The most common drivers are listed on this page: Driver Reference
- - Driver manufacturer links are on this page: Drivers and Downloads
To remove any left over driver remnants, especially from graphics cards, use driver sweeper http://www.guru3d.com/category/driversweeper/
Unfortunately your reports were not definitive, additional BSOD may occur as well as additional corrective action.
richc46,
thanx for your replay! i have done some of the things you suggested but the BSOD has appeard twice until now which is much better than usual.
first when the blue screen appeard i checked my drivers and it seams like the Consumer IR devices had a problem so i uninstalled it but it didn't stop the blue screens.
Also when i did the SFC Command scan some errors where not repaired, i have found in MS website that they can be repaired by doing this:
To determine which files could not be repaired by the System File Checker tool, follow these steps:
  1. Open an elevated command prompt.
  2. Type the following command, and then press ENTER: findstr /C:"[SR] Cannot repair member file" %windir%\logs\cbs\cbs.log >sfcdetails.txt
    Note The Sfcdetails.txt file contains details from every time that the System File Checker tool has been run on the computer. The file includes information about files that were not repaired by the System File Checker tool. Verify the date and time entries to determine the problem files that were found the last time that you ran the System File Checker tool.
  3. Type the following command, and then press ENTER: edit sfcdetails.txt
    The Sfcdetails.txt file uses the following format: Date/Time SFC detail
The following sample log file contains an entry for a file that could not be repaired:
2007-01-12 12:10:42, Info CSI 00000008 [SR] Cannot repair member file [l:34{17}]"Accessibility.dll" of Accessibility, Version = 6.0.6000.16386, pA = PROCESSOR_ARCHITECTURE_MSIL (8), Culture neutral, VersionScope neutral, PublicKeyToken = {l:8 b:b03f5f7f11d50a3a}, Type neutral, TypeName neutral, PublicKey neutral in the store, file is missing
If the System File Checker tool cannot repair a file, follow these steps:
  1. At an elevated command prompt, type the following command, and then press ENTER: takeown /f Path_And_File_Name
    For example, type takeown /f E:\windows\system32\jscript.dll.
  2. Type the following command, and then press ENTER to grant administrators full access to the file: icacls Path_And_File_Name /GRANT ADMINISTRATORS:F
    For example, type icacls E:\windows\system32\jscript.dll /grant administrators:F.
  3. Type the following command to replace the file with a known good copy of the file: Copy Path_And_File_Name_Of_Source_File Path_And_File_Name_Of_Destination
    For example, type copy E:\temp\jscript.dll E:\windows\system32\jscript.dll.
but when i write Sfcdetails.txt and press enter there's nothing wrriten in the file.
sorry for troubling you and ecscuse my bad english.
thnx.
Lina, First I want to give you all the help that you need. Your English is fine. Wherever you live, I would not know your language at all, so you are doing great. But now for the questions.
About the SFC, if errors were found run it several times. Problems do not get fixed all at once.
Try to run SFC a few more times. If there are still problems, I will help you open the file.
After you have completed all the steps, if you still get BSOD, just send the new dump.
We will work on it and get is solved. Dont worry, take your time, I am here for you.
richc46,
i have made the SFC scan 7 times but still some errors didn't get repaired.
On the other hand BSOD has appeard once yeaterday and it hasn't appeard again today :D
The sfc cannot fix all problems, if you ran it seven times, it has done all it can. To fix errors that cannot be corrected a repair install is required, but I think that it will not be needed in your case. Glad that the BSODs are less. If they continue and bother you send me the BSOD report.
Take your time, but try to do all the suggestions that I have made, I think the BSODs will stop.
Your are welcome, if any more problems just post and I will try to help.
