Solved problem loading
biscuit
hi all hope you all are having a great christmas. i have a sony vaio windows vista home preim.4gb ram,intel dual core,been playing kuma for a while,tried to run the game no good,allso internet explorer,google cromekeep getting,,,,hope it is a small problem,never the less hope you all have top new year,byeeeeeeeeeeeeee:party::geek::devil:
Hello biscuit,
Welcome to Vista Forums.
Did Kuma work fine and then quit, or did it work on a previous OS but doesn't work on Vista?
IE, google crome keep getting .... what? Describe what happens, pics of error messages (info on how here if needed. http://www.vistax64.com/tutorials/148532-how-use-snipping-tool-vista.html?ltr=H), what you've done to try to fix it would be helpful information.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
thanks,gary there was a problem with the proxy server,working fine now,a mate fixed it ,i think he re set internet explorer as well,thanks for the reply.....
Glad you got it sorted. :D
    Creative SB X-Fi
    HP w2207 + HPvs15
    MX Revolution
