Solved Problem with 32bit and 64bit
nostaw5
"POW" Ur dead
Power User
Hi im kinda new so ill need all the help i can get. in march i think my friend gave me a laptop. Sony Vaio. 1gb Ram all that.... x64... recently it crashed and i ran the recovery partition... now for some reason my laptop has gone from x64 to 32bit. yes it is 64bit capable but i dont have any installation cds with x64 on them... i was wondering if there was a way to change without a fresh installation with cds or recovery partiton (now deleted)
simply
if there is a way to change my pc BACK to x64
    Custom Gaming Rig 780G
    AMG Athlon II X2 255 3.8/2MB/2500MHz 45nm AM3
    Gigabyte GA-MA78LMT-S2 AM3, Core Boost, Ultra Durable 3
    2X 4GB Kingston DDR3 1066MHz @ 1666MHz Dual Channel
    HIS HD Radeon 7770 GHz Edition iCooler Core: 1000MHz
    Realtek HD Audio
    Dell E2311H DVI/VGA 5ms response, Full HD
    1920x1080 @ 60Hz
    320GB Seagate Barracuda 7200.02 SATA II
    Cooler Master Extreme Power Plus 700w
    Lian-Li PC-6010 With Side Window
    Aywun A4 80mm fan
    Logitech K120 Wired Mouse
    Logitech K120 Wired Keyboard
    802.11B/G/N 17Mb/s
    AMD Catalyst 12.6 Thomson A/B/G/N Router LiteON CD/DVD Player GAME PERFORMANCE: Battlefield 3: 41 FPS High 1x AA @ 1280x720 Mass Effect 2 and 3: 60 FPS Highest 4x AA @ 1920x1080 Counter Strike Source (and other Valve games): 300 FPS (max FPS in game) Highest settings 8x AA 16x AF @ 1920x1080!!!
Hello Nostaw, and welcome to Vista Forums.
I would that the 64-bit Vista was not the original OS installed, and that the 32-bit Vista is what was included with the computer originally on the recovery partition.
Unfortunately, you can only do a clean install when going from the 32-bit to 64-bit Vista, or the other way around. Since you have deleted the CD and recovery partition, you will now have no way of reinstalling the 32-bit Vista via a factory restore from them. Unless you have another Vista installation disc with a valid product key number for it you are out of luck and will need to purchase a new copy. If it comes down to that, you might consider Windows 7 instead.
Sorry, :(
