Problem with Booting!!!
dave7sky
HI
I have Toshiba Satelitte A215 and try to boot my windows Vista - while putting my CD and going by F12 button Boot menu i choose CD/DVD
everything goes fine till point where i need to pick disk to install it.
I see
DISK 0 Unallocated Space
but also got message - This computer's hardware may not support booting to this disk. Ensure that disk's controller is enabled in computer's BIOS menu....
Okay to get to BIOS i tried ESC button and then F1, F2 but really dont know where to go and how to do it and what?
when press F2 buton - System Utility i have menu bar - Main, Advanced, Display, Security, Boot and Exit
Old HDD is already there..... before that i tried to boot, everything went okay - everything was loaded, pc restarted and had info - please wait while windows is set up ur PC - but nothing happened - went off and i have this problem now.
maybe it will help too - prior to that my PC wouldn't load properly - was going into repair mode when attempting to fix - there was error coming up and was saying that disk is corrupted - so i was advised to boot it and install new vista....
PLEASE HELP
    Hp pavillion a6110n
    amd athlon 64 x2 live! 4400+
    4 gigs 3.3 useable
    generic pnp monitor
    7.2k rpm 1 linux ubuntu partition 1 vista partition 1recovery partition 1 windows 7 partition 1linux swap partition
    500W, antc earthwatts EA500
    normal black case
    fans
    saitek cyborg gaming keyboard
    dsl
    2.3 ghz amd
Yes i have tried to make another partition on unallocated disk but then have error coming up : failed to create new partition on the selected unused space error 0x80042453
Really run out of options now?!!
Help me
Do u think my disk is gone?
