Solved Problem with Dell Studio 17
abudman
Had to reinstall Windows Vista OS and of course lost everything. Reloaded the Drivers and utilities CD. Now cannot connect to my home network. “This computer does not have a network adapter installed and configured”. Went to device manager and under the “other devices” tab, everything under it has the yellow exclamation marks. Also the display is not right. Under the “display adapters” tab the “Standard VGA Graphics Adapter” also has the yellow exclamation mark. I have disabled and enabled all of them to no avail. Also checked the services and they seem to be started. Not sure exactly which ones should be started but all the ones about networking are running. Home network is working because I have other devices running from it just fine. I’m a little overwhelmed at this point. Also trying to sift through the archives at the same time. Any help will be greatly appreciated.
Hello, I would work on installing updates needed to get your OS up to date first , then I would work on latest drivers from Computer manufacture site with a combo of motherboard driver updates and graphics as well as audio drivers.
    Emachine ET 1161-05
    AMD Athlon 64 LE-1640
    1280x768 pixels
    ST316081 5AS SCSI Disk Device
    Tower
    Fan Speed 1247 RPM
    PS/2 Compatible Mouse
Thanks for getting back to me. I went to the MS site and got drivers on a thumb drive but for some reason they wont load. I'm ready to use this thing for target practice lol.
Maybe you have a bad install, seems you would be better off attempting a new install ?
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Try using Dell drivers , then you can get graphics and audio updates later, but, for now use what Dell has for you .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
I would get latest for model of Dell you have and then once you have them downloaded, place them on the Desktop and then unzip them , if needed , and start installing them .
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Got er done! I loaded the drivers and utilities cd once again. Opened the zip file and went one by one down the list of drivers and ended up with over 100 updates. That got everything going again. Now doing the Windows update and that should do it. Thanks for all your help. You guys rock.
It does take diligent effort and time, glad to hear you got it sorted out. Thanks for using VistaForums
    Emachine ET 1161-05
    1280x768 pixels
    Tower
    Fan Speed 1247 RPM
Thank you for using Vista Forums, be sure to come back often. I will mark this thread as solved.
