Hi! I'm running Vista Ultimate 64-bit. I have a 24" LG Flatron L246WP-BN HD widescreen monitor and an integrated Radeon HD 3300 GPU on my ASUS M3A78-T mobo. After buying the monitor I realized it wouldn't work properly with my old system so I built a completely new one. (Check out my full system specs.) The monitor's native resolution is 1920 x 1200.
The problem I'm having is that I can't set the resolution higher than 1280 x 720. If I do I lose almost one-half of my screen (everything shifts to the left so I can't even see my Start button, etc.).
Am I doing something wrong? What good is it having a widescreen 24" 1920 x 1200 HD monitor if I lose half the screen by setting it to it's native resolution?
Thanks for any help you can provide!
- Self-built
- AMD Phenom X4 9850 Black Edition
- ASUS M3A78-T
- Crucial 4GB 240PIN DDR2 DIMM Unbuffered
- Integrated ATI Radeon HD 3300 GPU
- On-Board
- LG Flatron 24" L246WP-BN
- Native 1920x1200
- Seagate SATA 320GB
 - PSU
- Enermax Pro 82+ 625W
 - Case
- Lian LI PC65
 - Cooling
- 4 80mm (2 front,1 rear, 1 top) + PSU fan
- Logitech MX1000
- Saitek Eclipse II
- Verizon DSL 3Mbps download 768Kbps upload
