Problem
jabani
Hi folks,need a lil help here with my pc, with the following specifications- 40GIG HD,512 RAM and WIN XP. It was formatted recently and lately its been showing me that the HD is full whereas the documents i have are not even up to 512MB. I know its a virus attack. I have an updated version of AVG antivirus and ran a complete system scan. How can i be able to fix the system without necessary formatting it.
Hello Jabani,
Welcome to Vista Forums.
What makes you think it is a virus? A 40 gig HD is kinda small for Vista in my opinion. Yes it can be done, but my clean install of Vista Ult.x64 takes up 25 gb (bit smaller for x86) with only AV installed. So add a couple gigs of programs, Restore points, page file etc.
You could try an online virus scan to be sure.
http://www.eset.com/onlinescan/
Dr.Web Virusscan [Online check]
http://www.kaspersky.com/kos/english/kavwebscan.html
Hope this helps.
Gary
    Intel Core2 Quad Q6600
    Creative SB X-Fi
    HP w2207 + HPvs15
    1680x1050 + 1024x768
    MX Revolution
    Microsoft Comfort Curve
Hello Jabani,
Free ESET Online Antivirus Scanner
Hope this helps.
Gary
just to let you know,he said hes using xp
    Intel(R) Core(TM)2 Quad CPU Q8400 @ 2.66GHz
    Elitegroup P43T-AD3
    4.0GB Ram DDR3
    GeForce 9600 GT
    Lenovo 1440 X 900 60Hz
    1440 X 900
    1TB
The OS is not vista,but XP. I did restore points but it didnt work,i dont understand the page file your talking about,how do you use it? and the programs,which one are you talking about?
    Creative SB X-Fi
    HP w2207 + HPvs15
    MX Revolution
