Problems installing ram in vista premium 32 bit.
I just bought new ram modules, OCZ pc2 9200 DDR2.
And when i shutdown my computer, and installs the ram (2x2 gb modules)
The system Bsod,
i dont even get the possibility of starting up in safe mode, cause the system hangs to. at the Bsod screen it says try push F8 to get start up menu and start up in safe mode, but since the sys hangs i cant.
i had 2x2 gb before also, but they are only at 600mhz, wich are the reason that i want to change the modules, the system runs fine with the old 2x2gb modules, why cant i change to these new ones?
I found a patch that was made by microsoft, wich was made because 4gb ram and Bsod was a common problem i guess, but when i try to install that patch, it says that the update isent relevant for my system.
Any one having any ideas what i might do?
The system Bsod,
