Hello, i am from Venezuela, so sorry for my english.
i've had some problems trying to install windows vista x64.
the problem is this: the cd boots and it load some libraries, so it works fine but when it is beggining the instalation, it says that "i have no drivers for the CD/DVD Rom device", so it says that if i have them in a pen drive (USB removable Device) or even in a CD, i can open the CD rom, change the Vista X64 cd, and put the drivers cd into de CD rom, and then it will work.
the problem is that i have the lite-on dual layer rewritable device, which serial model is : SOHW-1693S, so i dont know if i have to download them and put them into a pendrive, to use it later in the installation, or if i have to download SPECIAL VISTA DRIVERS for this device.
however, it would be very helpfull if anyone can solve my problem, because i've been trapped here 2 days, and i havent checked if my new SATA II 500 GB Device works with no problem.
(by the way, yes, this is A CLEAN INSTALLATION, because the hard drive is virgen, i installed it for the first time 2 days ago.)
thanx to everyone that can help me!
