Solved Problems
americancritic
Hello
I have a problem everytime I click my mouse when closing anything the mouse flash's the hour glass at the tip of the mouse and the bottom on my screen flash's a lot and can see the desktop for a second or so and it is getting worse everytime I click to leave the net or any programs encluding the forum. Any help would great, thanks to all..
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    LG W40 series widescreen
    1600 X 900
    300W
    Mid-Size ATX
    Microsoft Wireless Mouse 5000
    HP Multimedia Keyboard
you have way more expericns than me buddy, somy advise will prolly not help u much, but if it was me id prolly just do a restore point, and see if that works, if that didnt work, id come ask you guys, lol hope u get it figg, nice to tlk to u again 2 it has been a lil while.
    toshiba satellite
    Intel Pentium T2080 @ 1.73GHz 66 °C Yonah 65nm Technology
    TOSHIBA ISRAE (U2E1)
    Generic PnP Monitor (1440x900@60Hz) Mobile Intel(R) 945 Expr
Hi
I did a full factory restore about 4 months back and it was doing it then also, I know it can't be the mouse it has to be somehwere within the system, but thank you very much for your kind help on this matter, and if you have or find something that can help please re-post me...
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
im actuly looking around now, ill be sure and let u know bud, again nice tlkn to again
    toshiba satellite
Hello
May I ask what you are seeing at the Bottom of your Screen ...
How long has this issue been Going on for?
Josh
    Intel Core i5 2400 @ 3.10GHz
    Foxconn H67MP-S/-V/H67MP
    8.0GB DDR3 @ 665MHz (2GBx4)
    AMD HD Radeon 6870
    SMB1930NW (1440x900@60Hz)
    Novatech Night
    Dell HID-compliant mouse
Hello Americancritic,
As per your statement, in my opinion it sounds more like a vista aero description. Disable aero and check it.
Please post your result. By the way which mouse are you using?
Thanks.
Arvin
    HP dv2519tu pavillion Laptop
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    Conexant HD Smart Audio HD2
    HP Brightview Display
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
    4 MB/SEC-Download, 2 MB/SEC-Upload
Hello
I am using a Microsoft wireless mouse 5000...
I have had this problem for about 4 months then I did a complete factory restore...
But I had this problem before that to but not near as bad...
The last 2 weeks it has been the worse...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Have you tried to Reinstall the Drivers? Or change the Cursor
    AMD HD Radeon 6870
    Novatech Night
Try reloading the Microsoft Driver again or reset the mouse settings to default.
Microsoft Drivers Downloads
Let us know if it works. Can you tell me which security are you using?
Thanks.
Arvin
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
Do you use any "speed up my computer" type of software? these can cause strange mouse behavior.
Have you scanned for malware?
    Lenovo Thinkpad T400
    LENOVO 64734VM
    Conexant 20561 SmartAudio HD
    15 inch
    Medium for New Zealand
Try with a clean boot and see if the problem persists.
Good to see you back Richard
    LENOVO 64734VM
    15 inch
Hello
In the past 6 days I have done:
1. Done a full AV scan using Kaspersky internet security. None Found
2. Ran a full updated scan using malwarebytes. None Found
3. I have uninstalled the mouse software, then used my wrie mouse to reboot. No change it still does it...
4. I have uninstalled the driver and downloaded updated drive from M/S
5. Some things I do just to make sure, today I ran a full disk check, no problems found...
6. I never used it without it being the default, installed it and ran as is...
7. A couple of weeks back my IE8 had a BSOD it stopped running and said it had to close so no damage would be done to the computer or something along those lines. Forgot about that one..
Oh and I have never used anything to spped up my system just what's in it...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Ok mouse is worse and does it in safe mode also, any more suggestions, the mouse when exiting and hovering will blink the hour glass real fast like a fluttering...
Thanks
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Did you try a sfc scan. I have to say It sounds like malware or an incorrect driver to me.
    LENOVO 64734VM
    15 inch
I had just finished a full scan using malwarebytes before I posted, plus all the others I did over the last few days, there are no yellow warning flags next to any drivers. I am at a loss...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Hello
Here are the sfc results, as far as I can see it has something to do with,
Processor_Architecture...
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
This may sound crazy but it is worth a try.
Go to control panel under accessibility options
There is an option for the mouse to blink for people
that can not hear.
Atleast see what the setting are.
It is worth a try.
Jimmy
    Gateway
    intel core 2 Extreme QX6700
    intel
    3 gigs
    NVIDA
    Creative SB X-FI
    Gateway 24 HD Monitor
    1920 by 1200 pixels
    2-500 gigabyte hard drive Western digtal
Hello I think we have found the problem bad mouse why. I went in to the wireless software and it was not set as default, so i reset it and went on with business, well it started doing it again and I went back and it reset it's self again to a cursor with the hour glass I rest it again and you know the reset I will be going to the store tomorrow to get a new mouse, all the hours and things I did and it turns out to be this.. Thank you everyone for your help and someone needs to mark this as solved.
Tom
    a6530f Desktop
    HP-PAVILION
    M2N68-LA (Narra3)
    1600 X 900
    300W
    Mid-Size ATX
Glad to hear that your problem has been solved. We are really happy here that your long term frustrating problem has been solved.:D
I am going to mark this thread as solved. Happy computing.
Thanks
Arvin
    1.50 GHz
    Winstron
    2.5 gig RAM
    intel onboard
    1280X800
    SATA - 160 + 500 GB
    HP
    HP Laptop
    Air
    HP
    HP Laptop
