Program startup problem
greenwald
I've searched the forum but haven't found any similar posting.
I can't start any program (e.g. taskmanager, IE) after a system startup. The mouse pointer turns into the "waiting circle" and nothing happens. If I open the explorer (which is the only thing I've managed to start) the windows opens but with the message ontop saying "not responding". The only way out is to press the on/off button for some seconds.
I think I found a workaround and that is to first startup in safemode and then reboot. It has worked for five times.
Since it works after my workaround do I think it's not related to the HW. For me it seems that there is something in the system not starting up properly. Is there a way to find out which part causes this problem ?
I've also checked the logfiles and I can't see anything strange.
System configuration
Dell XPS M1530
Vista Home Premium + SP1
Thanks
    Dell XPS M1530
    Q6600
    MSI P36 NEO2
    4GB 5-5-5-12
    8800GTS 512Mb Overclocked
    5.1 surround sound
    500Gb Samsung SATAII XP 500GB Samsung SATAII
    1000W CoolerMaster power supply
    CoolerMaster Cosmos 1000 case
    120mm ThermalTake Big Typhoon CPU cooler, 3 x 120mm exhaust
    Wireless Keyboard and mouse 3000
    1TB WD My Book Office edition external drive x 2, Dual layer LG DVD-Rom burner, 15 in 1 card reader Triple boot: XP, Vista Ultimate 64 and Windows 7 Ultimate 64
In safe mode everything work fine?
1.Diagnose your system by using Reliability Monitor http://www.vistax64.com/tutorials/69535-reliabilty-monitor.html
2.If everything in safe mode work fine and there is no errors in Reliability Monitor try
Clean Boot procedure How to perform a clean boot procedure to determine whether background programs are interfering with a game or a program that you currently use
An update
I scanned for malware and didn't find any.
Flavius, About my "workaround". When the problem occurs I shutdown the computer the hard way by holding the on/off button for 5-7sec. Then I'll starts the computer and make sure to go into the safemode. The computer works fine and I performe a controlled restart. When the computer are back in normal state it just works fine.
I can't see any thing logged in the reliability monitor correlating to the problems I see. I will now try the Clean boot procedure.
    Dell XPS M1530
