program will not uninstall
IGY
Greetings from Vancouver Canada, I have just tried to uninstall a little word processing program named Rough Draft, because it was giving me error messages. But it will not go away, for though it is gone from the control panel, it still appears in All Programs in Start. When I tried to manually delete that folder, it denies me access. There is still a short cut on my desk top for Rough Draft, and if I click it, it still opens Rough Draft, but then that file will not close. Instead, a little window tells me, “Cannot create file\clip1.rtf” If I re-start my computer, the Rough Draft file will have closed. I am also getting notices on my desk top saying “Access Violation at address 004848 in Module Rough Draft.exe. Read of address 0000023c” I would be grateful if anyone could help me exorcise this little un-dead Zombie and get on with my life! Thanks, IGY
    What system?
    You guys must be joking, right?
The program may have had it's own un-installer...
You could re-install it and use it's uninstaller or you could give Revo Uninstaller a try...Free.
    Intel Q6600
    ASUS P5K MBoard.
    4G OCZ PC2 8500 Platinum
    EVGA 8800GTS Vid Card
    500G Seagate SATA 200G Seagate SATA 100G WD Caviar SATA 80G WD Caviar IDE
    OCZ Elite 800W PSU
    RaidMax Smilodon Case
    Lite-On dual layer DVD burner X 2 Dos 6.2;Win2K;XP; & Vista Ultimate 64Bit.
try UNLOCKER it is a free program,it has helped me when i can`t delete things & i get error messages,good luck
    amd phenom 9550 quad core
    asus
    4 gig
    samsung 20 inch
