Programs not appearing at Start/All Programs
rcalzadilla
I just got my new computer with Vista Home Premium x64, from Windows Professional XP.
Installed programs are not showing up at Start/All Programs.
Some are in directory C: Programs or Program Files (x86) and still dont't show up.
Help!
    Gamer Xtreme XT ( from Cyber Power Inc.)
    i7 920 2.66
    Gigabyte GA-EX58-UD4P
    6GB DDR3 Corsair SMS-1600 (2X3)
    eVGA Nvidia GeForce GTX260 896MB
    Sceptre 20"
    500GB SATA II 3.0GB 16MB 7200RPM
    Cyber Power 800 Watt
    Cooler Master Centurion 590
    Asetek Liquid for CPU only
    Comcast Cable Internet Service
the first thing i can think of, right off the top of my head, is during the installation process, were you given a prompt to "create start menu items?" or something similarly worded? it's happened to me before that you get into a mode to click all of the "next" buttons and inadvertently skip past the point where the program creates the start menu icons.
you can go to start > control panel > uninstall a program then single click the program(s) in question and at the top, see if you get the option to repair the program. if you don't get that option, you'll probably have to uninstall then reinstall the program(s).
    Garage PC
    Intel Pentium E3300 @ 2.5GHz
    BioStar G41-M7
    A-Data PC2-6400 (2 X 2GB)
    Diamond Radeon HD 4650
    Realtek
    HP Mx705 (CRT)
    1152x864
    LOGISYS PS480E12 480W
    Generic Barebones Case
    Stock Intel HSF
    Generic PS/2
    10 d / 1 u
Probably overlooked it at install.
Do you know why there are to Program Files and Program Files (x86)?
    i7 920 2.66
    Sceptre 20"
Maybe the programs x86 is for 32bit programs and the other is 64bit programs.
    HP Compaq Presario/SR5113WM
    AMD Athlon 64 X2 3600+ 1.9Ghz
    Asus M2N68-LA
    PNY Nvidia 8400 GS 256MB
    On board RealTek
    Acer X163W LCD
    1366x768
    Dynex 400w
    Nothin Special
    Stock
    Wireless Logitech LX7
    Comcrap 10mb cable
Rcalzadilla,
You can also manually create shortcuts by right clicking on the program's exe files in the C:\Program Files or C:\Program Files (x86) folder and click Send To and Desktop (create shortcut), then move the shortcut to the Start menu.
