(Resolved) Quick Launch Will Only Display Four Icons
skeezix
I reinstalled Windows Vista and the Quick Launch bar at the bottom of the window will not expand as I add icons to it. It never shows more that three icons. How can I fix this?
    Windows Vista SP2 32-bit Home Premium
    HP a6400f
    3 GB
    Integrated
    Samsung 27-inch
    500 GB Internal
    Not connected
Right click on the task bar and uncheck lock the task bar. You can then adjust the quick launch width.
    Windows 8.1 Industry Pro x64
    HP Pavillion Elite HPE-250f
    8 gb
    ATI Radeon HD 5770 1 gb ram
    Alienware 25 AW2521HF
    1920x1080 &1680x1050
    1 TB x2
    Dell Poweredge T140
    8GB 2666MT/s DDR4 ECC UDIMM
    1 TB & 360 GB x2
Thank you, I appreciate your help :)
    HP a6400f
    3 GB
    Integrated
    Samsung 27-inch
    500 GB Internal
    Not connected
