qus. for pro. only
brave76
hi all
friend of mine made special program for my pc(Timer)
but when i asked him to make his program popup with locked screen so no one can login without intering the neeeded password for his timer program
I need aprogram for standalone laptop like cyber cafe internet but i need to lock the pc and have timer only
I need aprogram-timer- that made force logout after spending 1hour from login +it should have screen not allowing users from using windows after they login but to inter the timer program password
anyone can help please!
What's wrong with the windows password?
If somebody really wanted to get on your computer, a password isn't going to stop them.
    Build #1
    Intel Core i7 3770K @4.4GHz
    ASUS P8Z77-V PRO
    Integrated on motherboard
    23" LG LCD/LED IPS
    1920*1080
    NZXT Phantom 410
    Self Build
    Asus P5Q Premium
    2 x ASUS EAH 4870 X 2 (Quad)
    Supreme FX 2
    CoolerMaster 1000
    Logitech G5
    Logitech G15
    20Mbps
Hello brave76, welcome to Vista Forums!
The easy way is to set the screen saver to do it for you, right click an empty spot on the desktop and select Screen Saver, set the time and put a check in the "On resume, display logon screen" box and click apply, anyone wanting to get in after that will have to enter the password.
click this image to enlarge
    * BFK Customs *
    Intel C2Q 9550 Yorkfield
    ASUS P5Q Pro
    8GB Dominator 8500C5D
    XFX ATI 1GB 4870 XXX
    Realtek HD 7-1
    1920x1080P & 1920x1200
    Corsair 620HX
    CM Cosmos RC-1000
    Razer Diamondback 3G
    HP Enhansed Multimedia
    18.6Mb/s
    My First Build ;)
