I figure I might as well post it in this forum to inform those who have my card (ASUS EAH4850 512MB). Currently after posting this topic in another forum, there seems to be no solution. Here is my conclusions from the situation.
If anyone has a different conclusion be my guest. I'm hoping for answers.
			- Sleep mode with Windows Vista Ultimate 32-bit does not work with multidisplays, using the radeon HD4850 running Catalyst 8.7 or Catalyst 8.8, when returning from sleep mode. It works only on a single display and will not work even when the secondary display is disabled. Monitors will display a blank screen and the power lights will flash indicating they are in standby even after the system has been restored from sleep mode. The secondary monitor must be physically detached from the graphics card (remove the DVI, AGP, or S-Video cable) for the system to return from sleep mode.
 - 3.6 Ghz AMD Phenom II X3 720 BE
 - Gigabyte MA790X-UDP4
 - 4GB OCZ DDR2 800Mhz
 - Asus EAH4850 512MB
 - Samsung SyncMaster 2253BW
 - C: 320GB Seagate SATA D: 720GB Seagate SATA
