Solved ram problem
elsmoke
my system doesnt recognize the 6 gb i installed
the pc is running windows home premium 32bits
this is the belarc advisor report, please help
Board: ASUSTeK Computer INC. Berkeley 1.04
Bus Clock: 267 megahertz
BIOS: American Megatrends Inc. 5.13 10/24/2007
3328 Megabytes Usable Installed Memory
Slot 'DIMM0' has 1024 MB
Slot 'DIMM1' has 2048 MB
Slot 'DIMM2' has 1024 MB
Slot 'DIMM3' has 2048 MB
Hi elsmoke and welcome to Vista Forums :party:
That is perfectly normal for a 32-bit system. A 32-bit Windows OS can only access a total of 4GB of memory address space. Into that space, all I/O devices are mapped. Depending on the hardware, this will take between 0.25GB - 0.75GB, leaving a usable memory value of something between 3.25GB and 3.75GB. In order to be able to use the full amount of memory installed, you will need the 64-bit OS.
    Dwarf Dwf/11/2012 r09/2013
    ASRock Z77 Extreme4-M
    ViewSonic VA1912w Widescreen
    Gigabyte IF233
You're welcome. :)
    Gigabyte IF233
